Air cleaner boot to carb replacement
Results 1 to 6 of 6
Like Tree6Likes
  • 3 Post By GaryL
  • 1 Post By GaryL
  • 2 Post By Xracer
Thread: Air cleaner boot to carb replacement
    Member UstaKood's Avatar
    Jan 2019
    Gun Lake Michigan
    46
    Hi all ,
    Buddy of mine brought his 92 over for some carb maintenance and the joint replacement was on the list .
    Yep , the rubber was rock hard . I just went thru this on my 87 over the winter , but pretty much had the bike apart on the bench . I ended up taking the whole *#**! air box out of the frame . Even then it was a chore .
    Just wondered if anyones had success doing this without removal of the air box ?
    I'm thinking removal of the rear tire and shock might allow enough access ?
    TIA
    Scott
    Scott
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,094
    I have replaced a few of these rock hard boots. Use a hair dryer on the hot setting which will soften the rubber enough to get it out. For installing the new one you can drop it in very hot water and grease the opening around the box to slide it in.
    Fred, jbfla and Xracer like this.
    1987 Yamaha BW350 Big Wheel
    Jan 2019
    Gun Lake Michigan
    46
    Thanks Gary , but I just went Gonzo with big screwdriver and hammer managed to pry it out
    I worried myself not wanting to damage the box .
    Scott
    Senior Member imlost's Avatar
    Sep 2017
    Portland, Oregon / East Cape, Baja Sur
    222
    The new boot is way easier to install than it is to take off. I took the seat off and worked at it from the top. You can use a long screwdriver to sort of "fold" the boot to one side to work it over the end of the carb.
    TWy to make a TWip to the TWails to make some TWacks.
    Jun 2013
    Forestburgh, NY
    8,094
    Quote Originally Posted by UstaKood View Post
    The old and hard boot is junk so I have cut them out, pryed them out and used a large screw driver. It is garbage so no worries except to not damage the box. The new one goes in real easy if you get it warm and have the end lubricated a little.
    Sthrnromr likes this.
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    As it is with so many things.
    Sthrnromr and GaryL like this.
  1. Air Cleaner intake Joint/Boot
    By alix in forum Technical Help
    Last Post: 08-20-2018, 04:59 AM
  2. Oil in air cleaner
    By Adrenaline taxidermy in forum Technical Help
    Last Post: 06-17-2016, 08:15 AM
  3. Foam air filter oil / cleaner.
    Last Post: 03-31-2016, 07:29 AM
  4. Carb Cleaner For Air Intake?
    By Avi Kwame in forum Technical Help
    Last Post: 02-18-2014, 07:48 PM
  5. WTB: carb and air boot
    By assquatch20 in forum TW200 Classifieds
    Last Post: 09-24-2010, 06:48 PM
