Pilot screw adjustment tool?
Results 1 to 10 of 14
Like Tree18Likes
Thread: Pilot screw adjustment tool?
    Member TWBigBlake's Avatar
    Apr 2019
    Tacoma, WA
    83
    Anyone made or found a tool that makes quick work of pilot screw adjustments? I don’t mind loosening the clamps and tilting the carb, but entry from the right side of the bike seems like if there’s the right stubby screwdriver or ratchet attachment it might be easier?
    Please post pictures of your methods, tools, or creations!
    jtomelliott49 likes this.
    18,424
    Stubby blade screwdriver can work but I now like just a 1/4' drive hex blade bit about 1.5 inch long.
    Darth likes this.
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    790
    I bought one of these plus an extra air screw in case I messed up, and modified so the new screw replaced the one that came with this.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I have a bunch of photos on how I did it, and if I find them, I'll attach here. But basically I just chucked up a drill bit in my press, clamped the air screw between a couple blocks of wood so I wouldn't damage it, then bore drilled away. I attached using Liquid Steel. This works great for me as I ride areas where the elevation can change by thousands of feet in a day. I've even been able to adjust based on air temperature; warmer air being less dense than cold air, damp air also less dense than dry air. When I go to the coast, I can adjust for that as well. Just a twist of knob as I ride to find the sweet spot and I'm rippin'!!
    The bear slayer!
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,602
    I've tried several different things on mine, they all worked, some easier & more/less accurate than others.
    If I was buying one for myself, or you, (I'm not!) I'd jump on this eBay Chinese special:
    https://www.ebay.com/itm/105-Degree-....c100008.m2219
    https://i.ebayimg.com/images/g/uGMAA...Wwk/s-l400.jpg
    $3.21 and free ship. That's one of those "Sore Willy" deals...you can't beat it!
    Estimated between Tue. Jun. 4 and Thu. Jun. 13.
    I've used one like this...Easy Peasy!
    And you don't have to rotate the carby.
    It shows it being used with a power drill.
    Just use fingers, of course!
    Fred likes this.
    Still, I rise!
    Humans: simultaneously capable of such genius and such douchebaggery!
    "Give a Damn"
    - C. M. Howe, Jr.
    Jun 2015
    Nova Scotia
    1,323
    Quote Originally Posted by Ski Pro 3 View Post
    This I would like to see....looks like a great idea and doesn't cost much. I ride year round and seasonal/weather based adjustment seems like a great idea. Weather patterns and air pressure changes wouldn't matter anymore!
    Sthrnromr and reddave like this.
    Senior Member Motoad's Avatar
    Oct 2014
    Creston, BC
    546
    Whittled this one down but I still find it hard to get in there. 20190521_141627 (Medium).jpg
    Fred likes this.
    Senior Member reddave's Avatar
    May 2018
    South Park, CO
    167
    Help us out with those pics Ski Pro!
    1987 Yamaha TW200
    Apr 2019
    Tacoma, WA
    83
    I just ordered this on amazon trying to avoid going mad scientist on perfectly good tools... we’ll see how this one works. Might be a good one for the books with all the people making regular temp/elevation adjustments!
    Once I saw you could just use the ratcheting disc by itself, it looks super low-profile and might be the perfect size to just place in your hand and line up coming in from the right side of the bike over the exhaust pipe.
    Sthrnromr likes this.
    Senior Member TW Newb's Avatar
    Dec 2018
    Los Angeles
    176
    R&D will make a cable that needs no modification.
    Trail Woman and Tweaker like this.
    2001 TW
    May 2014
    790
    Quote Originally Posted by TW Newb View Post
    That's a good idea! They didn't when I did mine around September of 2015. Or if they did, I didn't realize it.
    The bear slayer!
  1. Tw 200 pilot screw adjustment
    By Tw200quebec in forum Technical Help
    Last Post: 08-05-2017, 08:21 PM
  2. Pilot screw adjustment, first gen carb
    By mr.awesome in forum Technical Help
    Last Post: 07-04-2016, 07:02 AM
  3. Pilot Jet vs Pilot Screw adjustments
    By Tee Dubbs in forum Technical Help
    Last Post: 05-23-2016, 05:04 PM
  4. air pilot screw adjustment
    By dale124 in forum Technical Help
    Last Post: 02-02-2015, 08:58 PM
  5. Pilot Screw Adjustment Help
    By bodhi4 in forum Performance and Customization
    Last Post: 03-22-2013, 02:33 PM
