XT200 Damper Rod Holder
Results 1 to 8 of 8
Like Tree12Likes
  • 3 Post By Dwmdsen
  • 3 Post By Ken
  • 1 Post By Dwmdsen
  • 2 Post By TW-Brian
  • 3 Post By admiral
Thread: XT200 Damper Rod Holder
    Junior Member Dwmdsen's Avatar
    May 2019
    Pleasant Hill, CA
    7
    Since I have no idea on where to source a YM-33256 (Yamaha tool), I will weld a bolt to a threaded rod and make my own. My question is what size bolt will I need? Can someone tell me the correct size (measuring from flat side to opposite flat side). Thanks in advance.
    Ken, Darth and Miaugi like this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,844
    Here is what I use. My Stepdad made me a T-handle and welded a 21mm bolt onto the bottom of it. I thought this was a one time thing but I used it on the TW and also on my Yamaha Radian. I have done about 3 or 4 sets of forks with it. I also made a seal driver, the 1 1/2" PVC pipe with a chamfer on the end is my seal driver. It works great.
    The toes in the photo are extra and were not part of the tools.
    Fred, Xracer and tylermoney like this.
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,602
    Welcome aboard, Dwmdsen!
    Tell us about yourself and your bike...
    Still, I rise!
    Humans: simultaneously capable of such genius and such douchebaggery!
    "Give a Damn"
    - C. M. Howe, Jr.
    May 2019
    Pleasant Hill, CA
    7
    Just to add a bit of confusion, my work-around was a 19mm bolt (3/4" bolt) welded to a piece of threaded rod. Ken (above) used a 21mm bolt. Somewhere in all this lies the truth (or different fork retaining bolts).
    Ken likes this.
    Pleasanton, CA
    5,635
    I used a 3/4" bolt with couple of 3/4" nuts jammed together and some socket extensions.
    Ken and Sthrnromr like this.
    Ken
    Ken is offline
    Aug 2016
    Houston, Texas
    1,844
    I did a different bike with this procedure before also. It was the cheapest quickest alternative for that job.
    Ken
    Ken is offline
    Aug 2016
    Houston, Texas
    1,844
    Quote Originally Posted by Dwmdsen View Post
    After my post, then I realized you had put for XT200. I'm glad you figured out what you needed..
    Mine is a 1993 so maybe I got an odd ball. It did fit though.
    Frosty Hollow
    12,909
    I used something very similar to TW-Brians homemade tool on my '83 XT200's front forks when I replaced the seals.
    Sthrnromr, Miaugi and Ken like this.
  1. Replies: 5
    Last Post: 06-03-2016, 07:57 PM
  2. 1982 xt200 parts
    By gerard in forum TW200 Classifieds
    Last Post: 06-03-2016, 06:00 PM
  3. Steering Damper?
    By Rhodetrip in forum Performance and Customization
    Last Post: 10-27-2015, 10:37 AM
  4. fishing rod holder
    By howardgene63 in forum Performance and Customization
    Last Post: 03-28-2012, 11:32 AM
  5. 1982 XT200 Has Same Engine as TW200
    By ravenwoods in forum Technical Help
    Last Post: 06-18-2011, 10:25 AM
