Gearing
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By RockyTFS
Thread: Gearing
    Junior Member mmurdock's Avatar
    Jul 2015
    Kannapolis NC
    12
    Gearing
    Has anyone tried to run a 15 tooth front with a 55 rear. I know it would be slow. I'm thinking maybe 55mph tops. Im ok with that I want more torque on the low end.
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    773
    A larger front sprocket will actually make gearing higher. There are several here that have gone 13/55 and like the tractor pull. With 15 up front you would effectively pull the larger rear sprocket closer to stock torque.
    Hailey, ID
    3,377
    https://www.gearingcommander.com/
    Everything you could ever want to know about alternative gearing.
    Darth likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. Gearing change
    By [email protected] in forum General Discussion
    Last Post: 04-27-2012, 02:24 PM
  2. My First TW, Accessories and Gearing etc?
    By JayinMaine in forum General Discussion
    Last Post: 03-10-2012, 09:37 AM
  3. Best way to change gearing
    By sherm in forum Technical Help
    Last Post: 04-11-2011, 06:30 PM
  4. SoCal to Seattle: 1200 miles at 55mph with stock gearing?
    By tltmts in forum General Discussion
    Last Post: 08-17-2010, 09:12 AM
  5. Gearing different between 2000 and 2008 models?
    By kiloforce in forum General Discussion
    Last Post: 08-12-2010, 07:58 AM
