Choked my choke isn't working
Results 1 to 8 of 8
Like Tree17Likes
  • 1 Post By papa wheelie
  • 2 Post By Ski Pro 3
  • 4 Post By Fred
  • 4 Post By littletommy
  • 3 Post By Fred
  • 1 Post By elime
Thread: Choked my choke isn't working
    Junior Member papa wheelie's Avatar
    Mar 2012
    Vancouver, British Columbia
    29
    Hey Tdub community,
    Riding season arrived here a little while ago, so I pulled my Tw out of (dry) storage for the season after 6 months. Kept it winterized with a 3/4 full tank & fuel stabilizer. Pulled the choke out half way and it cranked but no start. Pulled it out full with same result. Had the choke pushed all the way in and gave it a little crack on the throttle and it started right up. I kept the idle steady until it was warmed up and I took it for a 30 min ride around town with no problems, whatsoever. When I came home I opened the choke half way and it died again. I was hoping everything would be fine after a good spin.
    I'm in the PNW and the temp was at 17c / 66F this morning. I replaced the chain and sprockets (15/50 so good!) but bike worked fine before I stored it. I haven't checked the condition of the spark plug because I have every deep socket except the 18mm. I do maintenance on my bike but have never done any carb work.
    Any idea why my choke is choking out?
    Thanks in advance.
    2002 TW200
    jtomelliott49 likes this.
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    790
    If your bike starts cold without problem and no choke, it's running too rich. How's idle speed? Try adjusting idle knob for effect. Take a rubber mallet and smack the carb a couple times too. That's all I got for now.
    The bear slayer!
    Mar 2012
    29
    Quote Originally Posted by Ski Pro 3 View Post
    I tried adjusting the idling screw down as well as up and both had no effect. It's idling normally at this point. When you say smack the carb are you talking about the float bowl?
    Thanks Ski Pro
    18,420
    A stock spark plug may be removed using the on-board OEM tool kit.
    As you speculate a carb smack could jar loose a sticking float needle, but a stuck float would usually cause much more serious symptoms.
    A carb smack could also free up a sticking needle. On some models the needle is held seated in it's holder by a small fairly weak spring. If bound up in it's holder the needle would always be partially lifted thus accounting for rich running behavior.
    Mar 2012
    29
    Tapping didn't seem to loosen anything up. Bike seems to run fine the way it is just have to use the throttle to warm it up rather than the choke. Is it bad to continue to ride it if it's running rich?
    Spokane, Washington
    17,229
    I always try a strong dose of SeaFoam first, try 3 or 4 ounces, ride around for a while and see if there is a difference.
    1st John 1:9
    John 3:16
    John 3:17
    18,420
    LT, how about "ride around for a Wheelie and see if there is a difference"?
    Glad to see Littletommy's input again, we missed you for awhile
    6,933
    What LT said only dump the old gas and start anew with fresh from the pump gas.
    littletommy likes this.
  1. My son got all choked up over this...
    By Flathats in forum Off-Topic
    Last Post: 12-03-2018, 05:10 PM
  2. Replies: 48
    Last Post: 06-28-2016, 08:44 PM
  3. All choked up
    By LuvNot in forum General Discussion
    Last Post: 07-01-2015, 07:26 PM
  4. Why Choke/ no choke?
    By rastaman in forum Technical Help
    Last Post: 01-01-2015, 05:04 PM
  5. carb kit for 1991?? Choke won't choke!
    By manotickmike in forum Technical Help
    Last Post: 06-05-2013, 02:55 PM
