Uh Oh! Ticking time bomb? Or something less drastic?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Like Tree73Likes
Thread: Uh Oh! Ticking time bomb? Or something less drastic?
    Senior Member Soulprogression108's Avatar
    Feb 2018
    129
    Ok so the little bike that could has had a little tick tock for a couple months. It started about three ago but has sat for last two while out of town.
    Starts out quiet and smooth but after half an hour or so ride it starts ticking away. It sounds like it’s in the engine. Happens at idle and gets faster as you speed up.
    Here’s a video. After a long ride it sounds pretty bad.
    It hasn’t lost any power and is otherwise running great. The oil looked great after a change. Also I checked the valves and they were in spec.
    My thoughts are maybe a ring is breaking down or the rocker arm is bent?
    Can anyone help diagnose. I hope it’s minor really can’t afford anything serious.
    https://youtu.be/TQ6RQb3WJa0
    Mahalos guys
    jtomelliott49 likes this.
    Mar 2015
    Ynys Môn
    4,587
    Sounds like exhaust gas escaping ......
    jtstdub and jtomelliott49 like this.
    - Hidden Content
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,088
    Sounds like the valves need adjusting which should NOT be done on a warm or hot engine.
    1987 Yamaha BW350 Big Wheel
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,929
    There are posts about the valve adjusting screws getting worn which leaves an excessive gap which causes the bike to click. When you measure the gap with a feeler gauge it can read ok because it measures across the whole surface of the valve adjusting screw and not the actual contact point. I suspect that is my clicking. I have the parts but haven't changed them yet.
    Frosty Hollow
    13,082
    Sounds like the valves need adjusting which should be done on a warm or hot engine.
    Maybe you meant "should not" be done on a warm or hot engine perhaps.
    Jun 2016
    New Rochelle, New York
    1,774
    Really doesn't sound that bad. I agree with the valve adjustment which you should check from time-to-time anyway.
    And the exhaust gasket could be loose or deteriorating too just from age and heat. Check to see if the bolts can use a slight tightening but be very careful. Those things have a tendency to snap-off and bring you bigger issues than a simple ticking sound.
    1995 BMW K75 (Elec Start)
    Jun 2013
    Forestburgh, NY
    8,088
    Thanks Admiral. Thought I said NOT in caps but must have held the CTRL key instead. I edited it.
    admiral, Darth and jtomelliott49 like this.
    Frosty Hollow
    13,082
    I was pretty certain you meant not warm or hot. I suck at typing too!
    GaryL and jtomelliott49 like this.
    Oct 2018
    Rural, South Carolina
    670
    Sounds like valve adjustment time to me, that's about it. Fairly easy to fix. Get errrr done.
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs
    Way too many past bikes and builds to list. I won't bore you. Questions? Just ask.
    Member BrotherJim's Avatar
    Jan 2019
    East Central Indiana
    31
    I had this happening with my '89. When I bought it, I thought the valves were a bit noisy and asked the seller about his adjustment intervals. He said he'd rather hear the valves than burn up his engine. Hmm, okay. One of the first things I did was check and adjust the valves (engine cold), but they always seemed noisy to me, even though the bike ran great. Adjusted again and again and the same thing. I couldn't stand it anymore! As it turned out, one of the keepers had gotten hammered (forget which valve) and a valve was bent, probably from never adjusting them! Although I do most of the necessary maintenance on my machines, I'm not the best mechanic, so I took it to a trusted local moto shop for the work. Cost me about $400 for the labor and some new parts. Problem solved and I couldn't be happier. Once sorted, you're still gonna hear the valves, but at a much lower, reasonable level. Good luck!
  1. Oh Oh Fire
    By Tuber in forum General Discussion
    Last Post: 10-26-2017, 10:02 PM
  2. See something say something.
    By Reddog in forum Off-Topic
    Last Post: 06-12-2016, 10:22 PM
  3. Replies: 2
    Last Post: 01-30-2015, 08:41 AM
  4. I trolled Flash Video bomb the news 2 months ago
    By Blackfire17 in forum Off-Topic
    Last Post: 11-23-2014, 11:17 PM
  5. Uh oh, I could have gone too far on this one!!!
    By admiral in forum General Discussion
    Last Post: 03-10-2011, 11:26 AM
