Need suspension upgrade
Results 1 to 8 of 8
Like Tree12Likes
  • 3 Post By Dozerash
  • 1 Post By Dozerash
  • 1 Post By Sthrnromr
  • 1 Post By Chip
  • 2 Post By RockyTFS
  • 1 Post By jtomelliott49
  • 1 Post By Fred
  • 2 Post By Maxpower
Thread: Need suspension upgrade
    Member Dozerash's Avatar
    Oct 2018
    Greene, NY
    39
    I rode my first real ride on my 09 TW this past weekend. I bought it last November and hadn’t really ridden it except around the lawn and field. I had a blast on the little TW! It’s plenty peppy enough for the back roads we were on. I was riding with my brother in law who is riding a CRF250L and kept up with him just fine! We rode around 60 miles of seasonal roads and back roads. The only complaint was if I hit a pothole it would bottom so hard that my license plate would somehow bend up! I weigh 260, so I figure I need stiffer springs. I understand there isn’t much adjustment to the shock. Any suggestions?
    Oct 2018
    Greene, NY
    39
    We had so much fun we are planning another ride this weekend! I’ll just have to try missing the potholes for now.
    jtomelliott49 likes this.
    Oct 2018
    Rural, South Carolina
    670
    This is what you need --> https://procycle.us/bikepages/tw200.html#shockspring , the 19 kg/mm one. Also you may want to look here for the front --> https://procycle.us/bikepages/tw200.html#fork-springs
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs
    Way too many past bikes and builds to list. I won't bore you. Questions? Just ask.
    Senior Member Chip's Avatar
    May 2017
    WI
    256
    Did you ride the CRF?? Might be time to upgrade.
    2017 XR650l
    2014 NC700X
    2005 ST-1300
    Wanted TW450
    Hailey, ID
    3,371
    Before you spend money on stiffer springs make sure the oil level is set correctly. Every TW I've ever heard of is set about 20 mm too low. Bring it up to 130 mm and try that, maybe even 125 mm at your weight. That is a maximum fill level, beyond which stiffer springs are necessary. Look in the tech write-ups for the procedure.
    Fred and jtomelliott49 like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Sep 2012
    Wichita, KS
    1,868
    Nice pics, thanks for sharing. I like the idea of trying improvements one at a time, to see what made the biggest difference. Our little TW's are pretty limited on suspension, so I wouldn't expect it to ride like a modern dirt bike.
    Fred likes this.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
    18,798
    I would agree with Rocky on verifying an appropriate amount of fork oil. This should be done whether or not stiffer springs are installed front and/or rear. The 09 likely has not seen a fork service in a while. As such the fork oil is likely contaminated with significant fine aluminum debris. Overall fork feel might be improved with a basic service including new seals if warranted. Similarly the rear shock can have it's preload increased from stock whether or not an aftermarket spring is installed.
    Feb 2017
    Waretown NJ
    554
    389.00. Sprung to your weight. For me on my bike it's a 100% improvement
    I also put Schrader valves on my fork caps to stiffen up the front
    https://www.yssusa.com
    https://images.app.goo.gl/zYUK1FZkUHthXBJ89
    jtomelliott49 and Sthrnromr like this.
    87 TW
  1. List with parts you will need to upgrade your TW to 214, 225 and up to 250 cc
    By macbig2k1 in forum Performance and Customization
    Last Post: 02-02-2018, 10:05 AM
  2. Stator upgrade options: need more power for heated gear
    By John Smallberries in forum Performance and Customization
    Last Post: 04-12-2016, 10:20 AM
  3. After rear suspension upgrade suggestions
    By play_in_mt in forum Performance and Customization
    Last Post: 03-02-2016, 09:30 PM
  4. Front and rear suspension mods
    By twjay in forum Technical Help
    Last Post: 11-25-2013, 04:33 PM
  5. Suspension Upgrade
    By Mongol Pete in forum Performance and Customization
    Last Post: 10-13-2013, 11:52 PM
