Rear sprocket
Results 1 to 10 of 19
Like Tree36Likes
Thread: Rear sprocket
    Junior Member dlddd34's Avatar
    May 2019
    East Texas
    1
    Question Rear sprocket
    Can anyone tell me if I can install a 54 tooth rear sprocket using the stock length chain?
    jtomelliott49 likes this.
    Oct 2018
    Rural, South Carolina
    670
    I do not believe so.
    https://sprocketcalculator.com
    dlddd34 and jtomelliott49 like this.
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs
    Way too many past bikes and builds to list. I won't bore you. Questions? Just ask.
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,718
    When you change out your sprockt, get yourself an O ring chain. You won't be adjusting your tension very often. As those stock chains stretch they start to wear on the teeth of the sprockets. I am running 60 teeth on my rear. Sure helps out on the trails where mostly you are just putting along under 15mph. I don't mind running the back roads at 50.
    Pleasanton, CA
    5,749
    Hi dlddd34, and welcome to the forum!
    How many miles do you have on your stock chain?
    Good(?) news is it may have stretched enough that it will work with the larger sprocket, the bad news is that if it does work then it is time to get a new chain.
    Brian
    Feb 2015
    Maple Ridge, BC, Canada
    1,561
    Quote Originally Posted by plumbstraight View Post
    Or you could try to find one of those pre stretched chains that Greg found in Moab.
    Purple and jtomelliott49 like this.
    Junior Member Rorr's Avatar
    Jun 2019
    Idaho
    4
    Plumbstraight, where did you get your 60T sprocket?
    18,858
    These guys supply all sorts of sizes. A 60 tooth for the TW starts at around $81 plus shipping.
    Home | Sprocket Specialists - World's Best Sprockets Since 1950
    https://sprocketspecialists.com/
    Another option is to drop a tooth count on the front sprocket. Going from 14 to 13 teeth in the front is about a 9% change while going from 50 to 60 teeth in the rear is about 12% change in overall drive ratios.
    Just to muddy the waters and make you folks break out the calculators I run 13 x 55 sprockets turning a 26" nominal diameter ATV tire.
    Sthrnromr likes this.
    Jun 2019
    Idaho
    4
    Any sprockets greater than 55T are aluminum. I've read in this forum, that aluminum = bad, steel = good.
    Do I need to be concerned about the larger sprockets being aluminum?
    I've used the calculator to see that I can get a similar torque improvement by going to a 13T front and 55T back. But, again, I've read on this forum, that 13T=bad.....
    So, I'm torn between going 14T front and 60T aluminum rear
    OR
    13T front and 55T all steel.
    Pleasanton, CA
    5,749
    Hi Rorr, and welcome to the forum!
    There is nothing inherently "good" or "bad" about aluminum or steel sprockets. It all depends upon the characteristics that are important to you, such as:
    -Weight - aluminum sprockets are typically lighter than steel
    -Durability - steel sprockets are typically more durable than steel from a wear standpoint
    -Appearance - steel sprockets can rust, while aluminum sprockets don't rust (although they will oxidize)
    -Cost - not sure about this but my guess is that they are both comparable
    -Availability - some sizes are only available in either steel or aluminum
    Again, there is nothing inherently "good" or "bad" about 13 or 14 tooth front sprockets, but there a few things to consider:
    -Rear sprockets are generally considered to be easier to change than the front sprocket. Also less chance to pinch wires if the front sprocket is not changed.
    -With the 13 tooth front sprocket, the chain is required to travel in a slightly tighter radius as it goes around the front sprocket. Theoretically, this may result in greater/faster wear on both the chain and the sprocket. From a practical standpoint, this is most likely inconsequential on a TW with a whopping 12 hp (claimed).
    Since you haven't told us where you live, what kind of riding that you do, and what if any mods your bike has, there may be other considerations that we are not aware of.
    Hope this helps,
    Brian
    Darth likes this.
    Jun 2019
    Idaho
    4
    I just bought a 2008 with 6K miles on it. It has been driven exclusively on the road. Everything is stock.
    It clearly needs a new chain - has original
    I plan on replacing the chain and both sprockets
    I intend to use it exclusively on trails/forest roads. Primarily as a hunting bike.
    I’m a pretty big guy - 6’ 3” 275lbs
    I want something that I won’t have to be slipping the clutch on steep terrain
    Expense is always a factor. I can get a 60T sprocket for $65 at pbisprockets.com. 55Ts are $25-$30. Anything bigger than 60T runs $80+
