Speedometer Starts Shaking after a While
Results 1 to 10 of 11
Like Tree16Likes
Thread: Speedometer Starts Shaking after a While
    Junior Member ElevenTSeven's Avatar
    Oct 2018
    Longview, Texas
    23
    During my trek up to Arkansas and back this weekend I noticed that after a couple hours of riding 55-65 mph, the speedometer started shaking/oscillating in a range of about 5-8 mph.
    I think it might be heat related, not sure how or why, but it seemed to start after long stretches of riding, and go away for a bit after a rest or fuel stop, then continue again after a while.
    If it is heat related then perhaps its more of a feature than a bug, bike letting me know its getting too hot and wants to stop for a spell?
    Has anyone else observed this with your bike(s)
    jtomelliott49 likes this.
    Pleasanton, CA
    5,749
    Most guys here only wish that their bikes could run for hours at 55-65mph !
    Now you know what Yamaha means with that 55+ Red Zone on the speedometer face .
    Seriously, is your speedometer actually shaking or is it just the needle that is jumping around?
    Junior Member Highway 61's Avatar
    Jul 2014
    Romeo, MI
    27
    Lube the cable.
    GOF, Fred and jtomelliott49 like this.
    Mar 2015
    Ynys Môn
    4,594
    Anything over 55mph and the whole bike gets nervous, causing various bits to shiver and shake
    Try talking to it calmly, and pat the tank occasionally - it'll soon learn to trust you ......
    - Hidden Content
    Oct 2018
    Longview, Texas
    23
    Sorry, when I said speedometer shaking I meant the needle shaking. Jumps around in a range of about 5-8 mph on the guage.
    Senior Member RaZed1's Avatar
    Oct 2015
    294
    Mine does that as well, but only after maybe 15-20 minutes of sustained 55+ speed. Normal around town it's fine.
    I've lubed the cable(usually the culprit for a bouncy speedo needle), it turns free/smooth as can be. The inner cable itself looks brand new, no fraying or anything. Honestly not really sure why it does this.
    Jul 2012
    Wet-ern Washington
    1,411
    Also make sure that the connections are seated and tight.
    - Leisure Time Larry -
    Hailey, ID
    3,377
    Yeah, my 2018 does this too, but since I rarely run at that speed for that long it is a fairly rare occurrence. The 2010 never did this.
    Edit: Today I ran some 60 miles at WOT trying to outrun a thunderstorm. No indication of this problem. Bike has 2,100 miles now....maybe it just wore in.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Junior Member jkaff's Avatar
    Feb 2019
    Chandler, Arizona
    3
    I took mine on a ride to the mountains using state highways. It was about 50 minutes one way. Towards the end of the ride there at 55 mph mine did this as well. Same for the ride back.
    Oct 2018
    Rural, South Carolina
    670
    Hrmmm. This is an strange behavior. Double check your speedo connection, clean, lube, tighten and see if that helps. These 2019s are seeming to have a few quirks. Odd.
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs
    Way too many past bikes and builds to list. I won't bore you. Questions? Just ask.
