Swing Arm Bobbins
Results 1 to 5 of 5
Like Tree7Likes
  • 2 Post By Michael Bryce Winnick
  • 3 Post By Purple
Thread: Swing Arm Bobbins
    Senior Member Michael Bryce Winnick's Avatar
    Oct 2015
    804
    Swing Arm Bobbins
    I have a Bonneville. Weight is about six hundred pounds. I do not want to run the bobbins through the hollow rear axle as is easily possible. I would rather replace my lower shock bolts with a universal 8mm bobbin. Is there any risk or downside to lifting the bike this way? No holes in the swing arm and I am not drilling and tapping to change that.
    Thanks
    Mar 2015
    Ynys Môn
    4,390
    You’ll have to make sure the paddock stand has clearance behind, not all of them do. If this is the twin shock bike, I’d be inclined to run a bolt through each shock with a long threaded end to the outside, and secure the shock with one nut, and the bobbin with a second nut. This will isolate the stresses of the two components. May seem like overkill, but that’s just the way my brain is wired
    On some of the more modern versions of bikes of this ilk, I’ve noticed a trend that introduces “bobbins” on the upper frame as some sort of crash mitigation device – eg it goes down the road on the bobbins, saving the bike. Be aware that if this creates a contact point with this in place, the sideways stress goes onto the swing arm, which it is not intended to take
    Other than the above – it’s all good …….
    - Hidden Content
    Oct 2015
    804
    I am not a fan of "sliders." By the time they are relevant I am dead. I have SW Motech Engine guards that bolt up on three points. I also have Free Spirit guards attached to my engine case. No sliders. No romantic image of me and the bike sliding and coming to a passive stop. I see my gazillion dollar clothes (klim) turning into confetti and me being on life support.
    Anyhow, I am back thinking about going through the axles the way the bobbins are intended to be installed.
    Purple--I like the way you think heavy duty and excess. There is no safe or excess in motorcycling. Thanks. MBW
    Smitty Blackstone and Purple like this.
    Senior Member UncleRandy's Avatar
    Feb 2015
    Alaska
    160
    MBW- I think your plan will work fine. I place jack stands under the bobbins on my V-Strom to remove the rear tire and do service. Works great, and looks cool.
    Oct 2015
    804
    Thanks. By using the shock bolts, I can leave the axles alone and pull the tire and service on the rear stand. Thanks for reading my mind. Why would anybody go through the axles and frustrate a tire change and service ability. At best you can lube the chain. I like the set up Purple put out there. MBW
