Jt rear sprocket 50t part number check
Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By old w/??
Thread: Jt rear sprocket 50t part number check
    Senior Member BUMBLESPECIMOODA's Avatar
    Sep 2018
    OSHAWA, ONTARIO, FASCISTVILLE (I MEAN CANADA).
    159
    I keep seeing the part number #1842.50, when ever I search for a JT sprocket. However, on sites that have a "Check the fit" option, when I enter the TW200 info, it always comes back as "it does not fit".
    Conflicting info sucks.
    Does any one know if this sprocket fits late model TW200's?
    Apr 2014
    982
    JTR1842.50 is the "stock" U.S. tooth count replacement size. JTR for rear sprocket -- JTF for front sprocket.
    Per JTS website; it and other tooth counts fit other bikes as well; mostly pre 2000 models.
    If you are looking for more street orientation (lower rpms "vibration" at speed - but less off-road ability "LOWER rear tooth count") -or- if looking for more off-road ability (with lower top speed "HIGHER rear tooth count") the tooth count is the number after the (.)
    Lots of info here regarding gearing choices.
    littletommy and jtstdub like this.
    Sep 2018
    159
    Thank you.
