Compression vis-a-vis adjusting the carburetor
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Fred
Thread: Compression vis-a-vis adjusting the carburetor
    Junior Member Dwmdsen's Avatar
    May 2019
    Pleasant Hill, CA
    7
    I'm resurrecting a '82 XT200 and an finding getting the bike to idle is a challenge. Compression is only 90 psi and I'm looking for validation that this could be some of my issue. I added a tablespoon of motor oil into the cylinder and compression picked up to 130 psi, so it would appear rings are suspect.
    Current setup: stock intake/exhaust, valve adjustment is within spec, carburetor has been fitted with standard OEM jets.
    Tennessee
    1,299
    You could be right, but I'd make very sure the carburetor isn't the culprit. Playing with jetting or just cleaning them again may help. Did you do the compression test with the engine cold or when warm? Compression can go up for a running engine. Doing a leak down test might be more telling. If you're willing and able, measuring the bore is probably the best way to be sure. I don't know if it's the same as the TW's numbers, but there's an acceptable range of wear in the cylinder and then there's what's out of tolerance. A service manual and a bore gauge can solve this if you're willing to go that far, but I'd try to check what's easily accessible first.
    18,813
    Try turning up the idle until bike can sustain itself, then ride it around and note how the bike is running overall.
    However it sounds like the '82 would really benefit from a top end re-build...appropriate new rings in a honed cylinder, new base gasket, maybe lap valves with new seals, new if not stiffer valve springs as long as head is off, etc.
    assquatch20 likes this.
    Oct 2018
    Rural, South Carolina
    670
    If I saw compression go from 90 to 130 without variable of engine temp, I’d lean towards rings and top end rebuild for sure. Especially on a new to you 82, unless you have the history and know the last time it was done (if ever). But, as others stated, carb tinkering is free and a place to start. My 2 cents.
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs
    Way too many past bikes and builds to list. I won't bore you. Questions? Just ask.
    6,981
    You say resurrecting.......I am guessing one or both of the compression ring is stuck. Getting the motor running for a while might free it up. I would try some Chemtool B12 in the spark plug hole and letting it sit overnight before I tore it all apart.
Tags for this Thread
