Gearing for mostly city/some highway?
Results 1 to 10 of 18
Like Tree12Likes
Thread: Gearing for mostly city/some highway?
    Junior Member bcazko's Avatar
    Jun 2019
    chicago
    4
    Smile Gearing for mostly city/some highway?
    Hey everyone,
    Just bought a 2007 T-Dub, to replace my 125cc scooter as my daily commuter. I live in Chicago and most of my riding will be around the in/around the city, in stop-and-go traffic, and some highway. I'm wondering what sprockets are ideal for this type of riding. It would be nice to not have to be in 3rd just to get through a light, and I also would like to keep my top speed up for the stretch of 60mph highway on my commute. I know a TW isn't the most practical tool for this type of riding, but for the time being I'd like to make the best of what I have. My MPG's aren't too great at the moment, how will changing gearing affect fuel efficiency?
    Any input is greatly appreciated!
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,466
    15/47 or a 45 with the stock 14 sprocket works for me on and off road. I tried 14/47 first and there was not enough difference.
    Senior Member elBuro's Avatar
    May 2013
    Boise foothills, Idaho
    103
    14/45
    I can do 65 on the flats in 5th, 55 up some pretty good grades in 4th (screaming).
    I have a DG slip on muffler, carb jetting and snorkel removed. YMMV.
    2006 TW200 CA version
    Senior Member YamTW87's Avatar
    Mar 2017
    Greece
    110
    First,change the front with a 15T one.
    If that's not enough, begin experimenting by decreasing the rear sprocket teeth until satisfied.
    If you want to cruise at 60 mph at max torque rpm, try 15F/45R.
    2007 Suzuki V-Strom 650
    Feb 2018
    Western Pa.
    261
    Quote Originally Posted by Peterb View Post
    I agree. Change tires to the Bridgestone TW203/204's and you have a great little street bike!
    Peterb and Darth like this.
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    699
    I ride about 85% on dirt. Some of my favorite longer/challenging trails are a 15 min road ride away, many are 5 min away. But last year I decided to switch to a 47 rear with front stock 14. I felt little change on trail a little at higher speeds. But switched back to stock for Moab and staying there. If you are road only/mostly in flat territory try 45 rear or even 15/45 for a real difference from stock set up. Stock front and switch to 47 rear was a very subtle change. Hardly worth it imo
    Don't expect to do any steep climbs tho
    Jun 2016
    New Rochelle, New York
    1,673
    From your description as an urban scooter rider that might jump on the freeway every once and awhile... you don't have to do anything. The bike is set-up perfect for your needs from the factory. The perceived owner "improvements" are mostly personal and tailored for whatever type or riding you are going to use the bike for. I am in no way any different from anyone else that poured a bunch of mods into my "dub". But in the end the most important ones revolved around comfort like a better seat (seat concepts), one inch risers, adults sized footpegs.
    The gearing change I did going to a 47T rear sprocket for better highway use was so minuscule that it really didn't make much difference. You can go extreme either way but highway gearing will take away off-road use. The same going the other direction. Sound like you don't need that. Best take away for me in that gearing change was replacing the stock bargain basement chain to an "X-Ring" chain. Perfect if you don't want to spend much time adjusting your chain (2000+ miles and no adjustment yet).
    As a city rider you might want to consider a rack or case for transporting stuff, lockable if a case. I have Cycleracks on both the front and the back. They are pricey and the front one is kinda a joke. But I will tell you that between the two racks they make excellent frame and overall bike protection if you drop the bike or for example if you park on the street and someone knocks your bike over trying to squeeze into a parking lot. They would be good urban protection and add a pair of Tusk hand protectors to protect you switch-gear too. They are cheap.
    I have a thread (not sure how to find it) as do a bunch or others listing mods they did along the way. You'll get more out of following some of those and deciding what you really "need" first and then what you "want". It's all fun and a great little bike to dress up and play with.
    PS: I just recently purchased an older used scooter, a 150cc Vespa. Such a great little bunch of fun and my new go-to-around-town-2-wheeler in the garage.
    Purple and Darth like this.
    1995 BMW K75 (Elec Start)
    Jun 2017
    Milwaukee, WI
    1,199
    I’m 175 lbs and I’m experimenting with 16 - 42 sprockets on my 01. It’s good for my city riding. But 5th gear becomes sorta useless on windy days and most hills. I wanted to bring the revs down and for that it is excellent. It bumped my mpgs up but not as much as I was expecting. I’m sure that’s due to all the time spent at red lights.
    My advice is that you can accomplish your goals by simply experimenting with the rear sprocket and not have to remove the left case cover to swap the front. If you’re looking for a place to start I’d say 14 - 45. If you’re heavier or have lots of heavy mods, our whopping 13 hp just can’t do much more at higher speeds.
    My 96 has stock gearing and it will hit 65 somewhat easily, but I’ve only ever done it once because it was screaming.
    My 89 has 15 - 45 and it gets to 70 but just runs outa oomph. Not screaming as bad. Again only did it once.
    My 01 with 16 - 42 can hit 75 but only on a downhill. The sound was not nearly as disturbing as the 96. Again only once. These bikes aren’t made for those speeds for extended periods. Change your oil often if you do.
    Just my opinions
    littletommy and Darth like this.
    01 street 203/204 RaceTech emulators (currently Dunlop K180s)
    96 hybrid Shinko 241/428
    89 back from the dead
    Junior Member Kelliemud's Avatar
    Dec 2018
    My girlfriend needs more highway speed and she weighs very little. Sounds like we will start with the 15t front. Is there a chain adjustment or linkage reduction required?
    Mar 2015
    Ynys Môn
    4,363
    No - just the three bikes ....
    TW200 - 1998 - Japanese import - 5000 miles on the clock - TW225 Special Edition 2007
Tags for this Thread
