New Member starting repairs
Results 1 to 10 of 12
Like Tree2Likes
Thread: New Member starting repairs
    Junior Member Vanquisher's Avatar
    Jun 2019
    4
    I have already flushed tank and petcock seems to be fine
    Junior Member DoubleDubs's Avatar
    Jun 2019
    4
    I just replaced the whole card with a rad racing model from Amazon it was 45$ and came in 2 days. I just bolted it up. I had to adjust the throttle cable length but other than that total plug and play, it may be rich bc I dont ever have to choke it, just open the throttle a little and it fires every time
    Jun 2019
    4
    Quote Originally Posted by DoubleDubs View Post
    I was wondering if this carb is still available and is it for a 1989 model
    18,424
    If DoubleDuds had listed the model year of his TW you would have been able to tell if his replacement carb would be a plug-n-play fit vanquisher's 1989 model year TW.
    This is because the airbox to carb rubber boots are different depending on pre-2000 and post 2000 TWs which have different carburetors.
    This is why it is important to list basic information about one's bike if one is trying to be helpful here.
    If one is trying to be really helpful then listing specific information like a link to the up-grade item or carb for sale is a very good idea.
    Welcome & good luck with the resurrection. Keep asking questions & forum members can help. Also investigate forum stickies for answers to commonly posed maintenance questions. Very little is new under the sun so a little research can dredge up answers to most questions, often with how-to pics & videos.
    Darth likes this.
    Mar 2015
    Ynys Môn
    4,484
    Fred likes this.
    - Hidden Content
    Jun 2019
    4
    I hope my question does not scare anyone away from any ideas
    Jan 2017
    Southern Nevada
    1,068
    Suggest that you remove carb, then clean debris from float valve, check float level, check jet orifices and reassemble
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    936
    You should never have to replace a carb unless you have physically broken or damaged something like one of the arms that hold the float pin or something else similar
    05-BMW1200GS- Rock Red 106k miles
    2013-TW200 - 8k- miles
    2018 X-MAX - 5k- miles
    18,424
    Most everything worthwhile on TW carburetors has been stated many a time in previous posts on this forum, often with helpful photos. No need to wait for someone to reply by re-creating the wheel. Simply use forum's search feature and/or review stickies to quickly access a vast wealth of information that should address every conceivable question.
    Jan 2017
    Southern Nevada
    1,068
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
