carb needle shims
Results 1 to 5 of 5
    Member aladdin's Avatar
    May 2012
    Grays Harbor, WA
    33
    Does anyone have the actual dimensions ID and OD of the shim washers for the carb needle on a 2003. I want to have the shims in hand before I take the carb apart. thanks in advance
    Sep 2012
    Northwestern Oregon
    1,092
    Have a look here: The Shims I Need
    May 2012
    Grays Harbor, WA
    33
    Quote Originally Posted by Old White Truck View Post
    Thank you
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    I used like #6 screw lock washers smashed flat about 30 cents
    Junior Member galacius29's Avatar
    Oct 2012
    10
    Does anybody have any extra shims? I was planning on raising it between .03 - .05 so would need about 5 shims. Will pay for your shipping or whatever..
  1. Late model carb needle shims, anyone got some?
    By Loppy in forum Performance and Customization
    Last Post: 08-15-2012, 04:09 PM
  2. In need of needle shims
    By PalmStateCrawler in forum Performance and Customization
    Last Post: 06-25-2012, 10:12 PM
  3. Carb Needle Shim Question
    By sfsccoter in forum Technical Help
    Last Post: 09-16-2011, 12:05 PM
  4. Carb Shims
    By Larry in forum TW200 Classifieds
    Last Post: 07-08-2011, 04:19 PM
  5. where can I get main jets and needle shims for 2006 TW
    By kennethshaw in forum Performance and Customization
    Last Post: 02-03-2011, 03:16 PM
needle shim
needle shims for yamaha tw200
tw200 needle shim
