fuel is pissing out the hose even when riding...why?
Results 1 to 5 of 5
Like Tree4Likes
  • 1 Post By ATTHECROSS
  • 1 Post By assquatch20
  • 2 Post By Chip
Thread: fuel is pissing out the hose even when riding...why?
    Junior Member ATTHECROSS's Avatar
    Sep 2017
    23
    Hello everyone-
    I can't figure out why fuel is pissing out of that hose onto the ground whether the cock is turned to fuel or reserve. The bike rides fine, but keeps leaking fuel whether I am stopped and idling or riding down the road. Any thoughts would be appreciated!
    Thanks for the help!
    littletommy likes this.
    I CONCERN MYSELF NOT, WITH THE CONSEQUENCES OF TRUTH - MICHAEL BOLDEA
    Tennessee
    1,299
    Sounds like your float valve/seat is leaking.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,086
    Stuck float valve! Check to make sure the float posts are not broken. You don't mention what year or where you are in the line of ownership so it is possible someone was in the carb before you and mucked something up.
    1987 Yamaha BW350 Big Wheel
    Senior Member Chip's Avatar
    May 2017
    WI
    257
    Your not going fast enough to burn up all the fuel.
    Sthrnromr and jerry58 like this.
    2017 XR650l
    2014 NC700X
    2005 ST-1300
    Wanted TW450
    18,803
    Stuck float valve, certainly one of the easiest to diagnose problems with our TWs.
    Fairly easy to fix too. Very occasionally tapping the carb body can free up the stuck needle valve but usually replacement is warranted. Use forum search feature to research old threads elaborating the necessary repair procedure in detail. Be careful driving float pivot pin out only in direction of the indicating arrow.
