Tuning carburetor on 1992 CA tw200 - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Like Tree11Likes
Thread: Tuning carburetor on 1992 CA tw200
  1. #11
    Junior Member efnick's Avatar
    Jun 2019
    California
    18
    By rip and strip, you mean remove and clean? I had removed the air filter prior to any work and checked, and it appeared that the P.O. had put in a newer, clean filter, it was slightly lubricated with what I'm assuming is filter oil and didnt appear to have any dirt in it, but I can certainly clean it with some soap and hot water and see if that makes any difference. I plan on replacing the battery and I've got a replacement coil on its way to me, so I guess I'll see how these changes affect it.
  2. #12
    Mar 2015
    Ynys Môn
    4,469
    Fairy 'nuff - you hadn't mentioned that previously - as the air filter is a prime component in carb issues, I thought I'd bring the matter up
    The "battery thing" was more of a "by the way" sort of a thing - yeah - it's on it's way out ....
    - Hidden Content
  3. #13
    Jun 2019
    California
    18
    For sure, much appreciated.
  5. #14
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,841
    Check battery posts and recommendations on the site. I got a small AGM battery for about $40.00 that is half the size and weight and outlasted my other batteries.
    1993 TW200 just shy of 46,000 miles
  6. #15
    Jun 2019
    California
    18
    swapped out the old coil for new this morning. Still has that flat spot at WOT, it sounds like a kind of rapid stuttering and jerks just slightly as it happens.
    on a side note, which brand/ model agm batter are you using? Thanks!
  7. #16
    Jun 2019
    California
    18
    Is there a possibility the float height is off, causing it to starve at WOT, but not through out the rest of the range? i tried attaching the old fuel drain hose to the float bowl and opening the screw to check what level the fuel would rise to, but it wasnt flowing out enough to fill the drain hose, however, if i unscrew it with no hose attached the fuel flows out of the float bowl drain no problem.
  8. #17
    Ken
    Ken is offline
    Aug 2016
    Houston, Texas
    1,841
    Quote Originally Posted by efnick View Post
    I got the Scorpian YTZ7S, $44.95 from Batterystuff.com at this time. I have been happy with it so far, a few months. It seems way better than all of the lead acid batteries I have had. I thought something was wrong with the starting system and was getting ready to trace all starting ground leads. It would turn over slow with a new lead acid battery. It works great with the AGM battery. That was from my post of 2/2017. It was smaller so I had to make spacers around it but it works great.
    That WOT issue sounds like you may be lacking fuel. You may want to put in a bigger main jet. Our bikes were designed pre-ethanol so ethanol runs a little leaner. I would only go up one size.
  9. #18
    Jun 2019
    California
    18
    I would love to order a new main jet and try it out, but I dont know what size would be a step up from stock. I couldnt read the number on the main jet when I had the bowl off of it initially and I have read that the carbs in the 92 CA version had totally different jetting than your later models.
  10. #19
    6,932
    I have written this before -- jets wear out. Start with a brand new #114 high speed jet and a brand new #40 pilot jets -- if you buy them from Yamaha. The hole in the center erodes and gets bigger and the mixture gets richer. I have had this problem on my two '87 TW's and a friend who using Euclidian logic determined his mid 90's TW mixture needed to be richer but ordered a new #114 jet at my insistence (along with a variety of richer jets), had to painfully admit I was correct (and thereby he was wrong) in that it was running to rich to begin with when he installed the new #114 and it ran perfectly. Ha ha! Fun to be right sometimes.
    Aliexpress sells about a dozen jets of you pick assorted sizes for about the cost of one jet from Yamaha. Ditto for pilot jets.
    And lastly, it could be your CDI going bad. Hopefully not.
    Where in Calif are you?
    Purple, admiral and Ken like this.
  11. #20
    Jun 2019
    California
    18
    Southern California, here is a picture of the fuel level using the trick to check the float level-
