Shifter seal removal
Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By CJ7Pilot
  • 1 Post By Fred
Thread: Shifter seal removal
    Member Errtu's Avatar
    Jul 2017
    Buena Vista, CO
    74
    My shifter seal is leaking oil.
    I have seen videos of the seal being removed and replaced without taking the cover off.
    Is this the same with the TW?
    I am getting conflicting part numbers. Is this correct for a 2001 (93102-12321-00) ?
    2001 Yamaha TW200
    2015 Nissan Xterra PRO-4X
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    210
    1988 Suzuki Savage
    1987 Yamaha TW200
    Jul 2017
    Buena Vista, CO
    74
    Yea that's the problem. I'm getting two different numbers depending where I look.
    93102-12106-00 and 93102-12321-00
    2001 Yamaha TW200
    Mar 2017
    Yuba City, CA
    376
    Quote Originally Posted by Errtu View Post
    Unfotunately, you'll need to remove the side cover.
    While you're at it, you might as well replace the output shaft seal, and maybe the support bearing seal as well.
    If either of these seals is leaking, oil can run down and drip out by the shifter.
    I replaced two shifter seals before I figured out it was my output shaft seal that was leaking.
    Take a look at your front sprocket while you've got it out, it might need replacing as well.
    Have fun!
    Sthrnromr likes this.
    Jul 2017
    Buena Vista, CO
    74
    Quote Originally Posted by CJ7Pilot View Post
    Have fun!
    Thanks for the info. I ordered a complete oil seal kit from Winderosa.
    2001 Yamaha TW200
    18,413
    Spin that output shaft's outer bearing too. If at all sandy or gritty now is the time to replace it. Pulling said bearing is not easy but not impossible, I used a modified Harbor Freight bearing puller that is available to loan..PM me if needed.
    Ooops, noticed CJ7Pilot mentioned the output shaft support bearing seal as well but not the bearing itself. Odd, figured a guy who runs a bearing business would be always trying to sell bearings...must just be an honest guy.
    CJ7Pilot likes this.
