Clutch Slip while bike is warming up
Results 1 to 8 of 8
Like Tree7Likes
  • 1 Post By edwards151
  • 1 Post By jeepster09
  • 1 Post By RockyTFS
  • 1 Post By Ken
  • 2 Post By Fred
Thread: Clutch Slip while bike is warming up
    Junior Member edwards151's Avatar
    Jul 2018
    Bozeman, MT
    10
    It seems that my clutch is slipping, more noticeably in higher gears, for the first 15 or so minutes of riding. I noticed this for the first time last summer a couple hundred miles after purchasing the bike from a private seller.
    The bike is a 2004, has 1500 miles on it, half of which are mine. I just changed the oil for the first time using Yamalube about 100 miles ago, but have no idea what was in it previously.
    I understand that using the wrong oil can cause slipping so maybe the previous owner used some oil with additives? It seems like the bike has too low of miles for the clutch to be worn. Iíve checked and adjusted the clutch lever free play and that hasnít made a difference. Are there any articles/videos out there on how to adjust the clutch, if thatís what is needed? Or do I need new clutch plates??
    Thanks in advance.
    jtomelliott49 likes this.
    Senior Member jeepster09's Avatar
    Nov 2010
    Twin Cities Minnesota
    147
    My last TW did that and I ended up replacing clutch. Not a very hard job.
    "Life Member NRA"
    Hailey, ID
    3,265
    Yes, most likely the PO used any old oil, not one for wet clutches. If so, you will need to replace the clutch plates. Since you have to do it anyway, go for Barnett plates and springs. You will never have that problem again!
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,842
    I never changed them out when my clutches slipped from non-wet clutch oil. I just did an oil change and added 4 ounces of Lucas Heavy Duty Oil Stabilizer then filled the rest up with wet clutch oil. I never changed them out when my clutches slipped from non-wet clutch oil. I used non-wet clutch oil on a regular basis for a long time and I just ran the Lucas in it and never had a problem. 42,000 miles on that set of clutches and they weren't really worn out.
    1993 TW200 just shy of 46,000 miles
    Hailey, ID
    3,265
    That's interesting. Never heard of that product.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    18,413
    Lucas makes a wide range of some very good products mostly centered around their proprietary compound. Founded by Forest Lucas this company is a great example of American capitalism and how a self taught simple man can make a fortune, treat his employees exceptionally well while contributing to many a philanthropic causes. He started out with a trucking company and desired something to improve fuel mileage, reduce engine wear and basically keep his fleet on the road longer and more economically. Happy workers, a good product line, gives back to the community...this free enterprise is what makes America great. His trucking company only suffered when the government's Interstate Commerce Commission complicated process for small trucking firms to operate in 48 states. Little companies just can't pay lobbyists as much as the majors for preferential treatment .
    Ken and jbfla like this.
    2006 TW200 "Nibbler", a.k.a. ďMr.Gizmo"
    Hidden Content All Things Considered Iíld Rather Be Motorcycling
    Mar 2015
    Ynys MŰn
    4,475
    Is this the "Prince of Darkness" ?
    - Hidden Content
    Hailey, ID
    3,265
    No, it's his nephew.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
