Rear Sprocket options
Results 1 to 9 of 9
    Member aladdin's Avatar
    May 2012
    Grays Harbor, WA
    33
    Are all the after market rear sprockets thinner where the bolts go thru. [counter bored at the center] I want to try a 54 or 55 tooth. It looks like Yamaha only offers the 50 tooth.
    Sep 2011
    Southcoast MAsshole
    2,661
    not sure if all of them are but JT sprockets are like that...
    https://tw200forum.com/index.php?/top...__1#entry64562
    Frosty Hollow
    13,042
    I recently purchased a Sunstar 55T from Procycle and it did not have the recessed area similar to the JT sprockets. The bolt area is the full thickness as the rest of the sprocket.
    May 2012
    Grays Harbor, WA
    33
    Now that is interesting. When I got the bike it had a 47 tooth Sunstar and it was recessed.
    Desert, SoCal
    7,369
    Quote Originally Posted by aladdin View Post
    Just curious. What's your objection to the recess?
    Senior Member xdac's Avatar
    Mar 2011
    Gilbert AZ
    1,076
    FURGETDABOUTIT
    Desert, SoCal
    7,369
    Chuddup, you!
    May 2012
    Grays Harbor, WA
    33
    If there is a non recessed option available it would be my first choice. yes I have been called anal more than once.
    Desert, SoCal
    7,369
    If we were running a 428-width sprocket with three times the horsepower I'd share your concern. The recessed versions were designed to reduce weight in steel sprockets without cmpromising strength. There is no real advantage to full-width steel sprockets. The old wive's tale applies to aluminum sprockets, which used to warp or break out their center sections if they were thinned in that area.
    I hope that eases your mind and opens up more options.
  1. Rear Mudguard Options for rebuild
    By bluebossa in forum Performance and Customization
    Last Post: 09-14-2012, 07:18 AM
  2. Replies: 0
  3. 60T Rear Sprocket??
    By NHebayer in forum Technical Help
    Last Post: 06-11-2012, 11:35 AM
  4. rear sprocket
    By phazer in forum Technical Help
    Last Post: 08-23-2011, 03:23 PM
  5. New Rear sprocket problem
    By mga60tw in forum Technical Help
    Last Post: 11-13-2010, 01:12 PM
