Hesitation/ Sputter on Fast throttle opening.
Results 1 to 10 of 13
Like Tree4Likes
Thread: Hesitation/ Sputter on Fast throttle opening.
    Junior Member madyammy700's Avatar
    Jun 2018
    19
    I have a 2013 TW with 4600km (under 3000 miles) itís mostly stock with the exception of some jetting.
    Iíve changed that trying to chase down a hesitation issue.
    I went from a 128 main to a 130. I went from a 31 pilot to a 34 pilot.
    I tried needles shims. 1, 2, 3, none... nothing really changes it.
    I have my air fuel at 2 turns now, but have tweaked that with no change to my issue. It affects idle speed and initial throttle response but thatís it.
    I have stock filter and exhaust and have installed new plug.
    When riding at lower rpms and I whack the throttle, it chokes, Hesitates, sputters... (whatever you want to call it), then revs up.
    The bike idles perfect and works awesome on top end with no fuss.
    Itís just the quick throttle opening that chokes it.
    What can I do?
    Iíve tried a couple different carb slide springs I had in a tool box, no real change.
    Itís really annoying.
    Please help.
    Sent from my iPhone using Tapatalk Pro
    Jun 2018
    19
    Forgot to add... Iím at Sea level for elevation.
    BC
    653
    Sounds like you are overly rich.
    Well not necessarily YOU...but the air-fuel mixture sounds to be overly enriched.
    Is the inside of your exhaust pipe black with soot?
    Do you get any backfiring while riding?
    What does your spark plug look like?
    Can you start without choke?
    Did you have this problem BEFORE you changed jets?
    My 01 was completely stock and would go from sea level to over 5000' without issues.
    2008 TW200
    Southwest corner of BC Canada
    Mar 2015
    Ynys MŰn
    4,586
    So when you whack the throttle, you’re shifting the potential from the idle jet, to the main jet, but only after around 35%. But if the idle is running rich, that will choke the entire process before the main jet takes over
    Wind it back down to a 31 pilot and see what happens ….
    MtnMan75 likes this.
    - Hidden Content
    Jun 2018
    19
    I had the problem before the jetting change. Itís the reason I was jetting.
    I thought sure it was just a lean pilot and a lager one with some needle shims and fuel screw tweek and it would be good.
    The tail pipe is clean like almost white glove clean.
    The plug is clean as well
    The cleanest plug pic is the newer one with 50 miles running on the new jetting. The old one was what I removed from before the jets and after. I swapped plugs to eliminate as an issue.
    I used to get major popping on deceleration but now thatís almost completely gone. If Iím going down a long hill and off the throttle, I might get one or 2 little pops in 10-15 seconds.
    The bike needs a touch of choke to start, but not for long. Also before and now, I needs a little throttle input to fire up smoothly . Like just a little blip as you hit the starter button.
    Dec 2017
    Western Washington
    212
    Try removing the air filter and cover to allow as much air into the air box as possible. This would be a test. It might be wanting a little more air. If this works maybe a higher flow filter may help. It may not do a thing, buts it a cheap test.
    Also check all your carb boots for good seals.
    1972 Yamaha DT 175, 1974 Kawasaki 125, 1976 Suzuki TM 250, 1979 Yamaha 750, 1977 Husquvarna 360, 1979 Husquvarna 250, (2) 1980 Suzuki RM 400ís, 1971 Husquvarna 400, 1983 Honda V65 Magna, 1987 Suzuki 230 Quad, 1987 TW200, 1990 TW200, 1996 Honda XR 650, 1998 Yamaha 300 King Quad, 2000 Harley Davidson Heritage, 2006 Kawasaki KLX 250s, 2007 Arctic Cat 650 Quad, 2010 Polaris Sportsman 850 Quad, 2006 Yamaha Grizzly 660 Quad, 2002 TW200, 1995 TW200, 2008 TW200, 2016 TW200.
    Jan 2017
    Southern Nevada
    1,077
    Hesitation/balking/stumbling is usually a lean issue, as opposed to blubbering, if rich.
    Check for a vacuum leak, which has the most effect at low RPMs.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Senior Member imlost's Avatar
    Sep 2017
    Portland, Oregon / East Cape, Baja Sur
    221
    Pull your petcock and make sure the screen isn't clogged. Replace any other fuel filters you may have. Make sure your fuel line is not kinked.
    TWy to make a TWip to the TWails to make some TWacks.
    BC
    653
    Quote Originally Posted by SportsterDoc View Post
    That would be the next thing to check when the signs of "overly rich" aren't there...
    Make sure the diaphragm is whole, without cuts or holes and/or isn't pinched under the cap.
    Also check float level if you haven't already.
    Go back to STOCK jetting and start from scratch to establish a baseline, as I mentioned...mine was bone stock and I had no issues with stumbling or hesitation, so you can go back to stock jetting, since that obviously isn't the issue. Once you've got the problem worked out...you can play with the jetting and note how each change affects performance.
    If you try to solve the problem without a STOCK engine...you're going to be chasing your tail for a while.
    Here is the test I was told to perform on my old XT225 - which has the exact same engine as the TW (minus the extra long output shaft).
    Once you think you have your jetting/carb/exhaust/airbox done right...get the engine warmed up and head for a long, straight piece of road...
    Start rolling and shift into highest gear (5th)...and while moving about 20 mph give her full throttle.
    She should accelerate smoothly, all the way up to top speed without missing, burbling or backfiring...once this test is successful, you have everything right.
    2008 TW200
    6,981
    I agree with TW in BC to check your float level. Maybe even raise it a teeny bit. And with SportsterDoc to look for vacuum leaks.
    Other than that get a carburetor with an accelerator pump......or live with it. My TW does the same thing when it is cold but once thoroughly warmed up it doesn't.
