1987 wiring harness
Results 1 to 10 of 11
Like Tree2Likes
Thread: 1987 wiring harness
    Junior Member OrinJohnson's Avatar
    May 2019
    Ashland OR
    11
    1987 wiring harness
    Anyone have any ideas on where to get a good wiring harness? Ebay is what comes to mind, I just feel like there's a good chance I could get swindled, especially because I'm fairly new to auto mechanics and am not entirely sure what i'm looking at.
    Senior Member WECSOG's Avatar
    Jun 2015
    2,417 miles from LT! ;-]
    742
    Ebay is probably your best way to go, simply because it will probably be difficult to find one anywhere else.
    A couple of comments: if you're sure you want to retain your '87 electrics, make sure the harness you are looking at shows only 1987 in its fitment chart. I just saw one listed as fitting 1987 through 2008. There's no telling what you would get there, because '87 through '08 covers at least three different harnesses.
    My recommendation would be to get the harness that fits 2002(ish; don't remember exactly if '01 is the same) to present and get a side cover, stator, flywheel and new CDI to match. It will probably cost around $500 total for the parts. That's what I did to my '87 because I want it to be around for the long haul and parts availability for the newer ones is much better.
    GOF likes this.
    '87 TW200
    '94 Sportster 1200
    '74 XL70 Frankenbike
    '76 CT90
    '72 CT70
    '72 XL250
    Senior Member imlost's Avatar
    Sep 2017
    Portland, Oregon / East Cape, Baja Sur
    222
    Why does your harness need to be replaced?
    TWy to make a TWip to the TWails to make some TWacks.
    May 2019
    Ashland OR
    11
    Since I got my tw, (4 months ago) none of the electrics have been working. I've pulled everything apart and traced back a lot of the wires and a lot of them are missing, have sketchy crimps, etc. I spoke with a mechanic about what I should do and he told me that my best bet would be to get a new harness and he'd pull it all out and replace it. Much less labor, it would be cheaper than having him go through and replace every wire individually, re crimp things, etc.
    Jun 2015
    742
    I forgot to mention that the price of a new 1987 cdi is more than double the price of the cdi for the current model... if you can even find a new '87 cdi.
    '87 TW200
    '94 Sportster 1200
    '76 CT90
    '72 CT70
    '72 XL250
    Sep 2017
    222
    There are a lot of '87 owners in this forum, including myself. I'm happy to help you figure where wires are supposed to connect, if you decide to resurrect your existing wiring. My '87 was in pretty sad shape when I got it, but the electrical problems were mostly due to oxidized contacts, and it was fairly easy to figure it all out.
    Regarding the CDI - I ended up having to replace mine, but i didn't go with OEM. I bought one from Waterloo Specialties (cdiparts.com), and it worked out really well for me. Considerably less $ than OEM.
    May 2019
    Ashland OR
    11
    I really appreciate the offer. My concern is just that I would need a lot of help. I have no experience with wiring on anything, let alone a motorcycle. I also want to get this finished up as soon as possible, riding season is ticking away fast.
    Sep 2017
    222
    Quote Originally Posted by OrinJohnson View Post
    Did your mechanic show you evidence that proves the harness needs to be replaced, or is that just his opinion? A harness can take a lot of extreme exposure, so I'm wondering if you're just getting the run around.
    Replacing the harness isn't easy, either. I think it may actually be easiier to troublshoot what you have. Maybe someone who has done this can give you their opinion.
    May 2019
    Ashland OR
    11
    I have it in a different shop right now being looked at. I may be back looking for help depending on what I'm told by this guy. Thanks to you all
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    378
    I would try to fix what you have. But if you end up replacing the harness you may want to consider what someone else said and replace it with an updated version and the matching stator, flywheel, cover, etc. Problem with the '87 is that it is the only year to use that electric system.
    jtomelliott49 likes this.
    1988 Suzuki Savage
    1987 Yamaha TW200
