spark plug wire insulator
Results 1 to 2 of 2
    Junior Member azbusmo's Avatar
    Dec 2012
    Prescott Arizona
    25
    the spark plug wire insulator, the outer one, was sun damaged. I cut it off and would like to replace it. necessary?
    the old outter insulator tube was a bit loose on the plug wire. like that when new?
    any suggestions for a replacement material? I have a clear vinyl(?)tubing that will work. my main question: can I pull off the plug connector and put it back on without damaging it, so I can slip the tubing on?
    the TW is a 1987.
    Member canadainshiver's Avatar
    Oct 2011
    New Brunswick, Canada
    77
    I'm not an expert, but would say it is not necessary. I took mine off. May depend on your climate and the riding you do (just how hot it gets in there). I'm usually not going slow & it is cooler here.
    My $0.02
    1991 TW200 Hidden Content
  1. Replies: 2
    Last Post: 07-21-2012, 12:44 AM
  2. Spark plug
    Last Post: 05-09-2012, 08:19 AM
  3. Spark plug pic
    By mjlater in forum Technical Help
    Last Post: 03-24-2012, 05:13 PM
  4. How to change the spark plug wire?
    By Sverige21 in forum Technical Help
    Last Post: 05-27-2011, 08:37 PM
  5. Spark plug wire change
    Last Post: 04-20-2011, 08:30 PM
1991 tw200 plug wire
