Starter Switch Trouble
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By Purple
  • 1 Post By GaryL
Thread: Starter Switch Trouble
    Member Hambone's Avatar
    Apr 2014
    Sour Lake, Texas
    34
    For a while, I've experienced problems with the starter switch on my 2013 TW200. When the problem started, it was a once in a blue moon occurrence. The switch would simply make a clicking sound that came from under the tank. It might happen once or twice but then the beast would start. The problem has gotten worse as of late and now the switch needs to be pushed ten or twenty times before it works. The battery is new and fully charged.
    Before I begin to trouble shoot the cause, I would appreciate any input from others who might be familiar with this problem and what the most likely cause might be.
    Thanks!
    Jan 2017
    Southern Nevada
    1,077
    What is battery voltage:
    1. Key off?
    2. Key on?
    3. While cranking?
    4. What is condition of BOTH ends of BOTH battery cables?
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Mar 2019
    Austin Tx
    251
    Maybe a loose connection that only works when "wiggled" (aka toggling the switch) and is getting worse from use. Take the seat and tank off and look at all the connections.
    2019 Yamaha TW200
    - DGv2 Slip On
    - Custom Oil Cooler
    - Manracks Seat Rack
    - Ricochet Skid Plate
    - Oversizzed Footpegs
    - Cycra ProBend Handguards
    1973 Yamaha RD350
    Mar 2015
    Ynys Môn
    4,594
    Relay ...
    Hambone likes this.
    - Hidden Content
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,094
    Check the tabs in the push button to make sure they are not corroded or burnt. Then check the connections from the button to the relay after you are 100% positive the battery and it's connections are good. The relay is a common culprit and ridiculously expensive from Yamaha, like $60 but stupid cheap on Ebay, like $8, buy 2.
    There is a way to test the relay I found on Fattireconversions.com and listed in the BW350 service manual on that site, same relay on the BWs as the TWs. Go here and scroll down to the Electrical starting system and they show the test procedure. https://fattireconversions.com/bw350...tml#electrical
    Hambone likes this.
    1987 Yamaha BW350 Big Wheel
    Jan 2017
    Southern Nevada
    1,077
    Posts 4 & 5 are likely answers, but a few preliminary diagnostics are appropriate before going there.
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Jun 2016
    New Rochelle, New York
    1,775
    All of the above and get yourself a kick-starter so you don't have to be a slave to that Magic Button working or not.
    TW is one of the few bikes made in the world today that you can still do this to.
    1995 BMW K75 (Elec Start)
    Apr 2014
    Sour Lake, Texas
    34
    I managed to buy a complete kick starter kit and installed it last year. I'm glad I did it.
