Rapid oil leak
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Rapid oil leak
    Senior Member kdick91's Avatar
    Sep 2012
    TX
    188
    So I'm losing a solid 3-4 drops every time I stop somewhere. If oil is thinned, I can lose as much as a two-quarter sized puddle! I check the oil level EVERY time before I start the bike and it regularly sits just under the top line! When it drips, it leaves gold drops in the snow so I know it's fresh oil. Currently, my oil filter cover is leaking and my base gasket is leaking. My question is, could the gasket between the two pieces of crankcase be leaking?? It appears to come from there as it is dripping in the dead center of the motor, but I cannot dismiss it as the base gasket dripping. Is this common for this gasket between the crankcase pieces to leak? Bike is an '06 with ~6000 miles. I cannot find the replacement gasket to save my life if this is the issue.
    Thanks,
    Kyle
    Gone - 2006 TW200
    Gone - 2014 CB1100
    2015 WR250R - Bored, stroked
    Gone - 2000 Trans Am
    Stolen - 2007 Trailblazer SS
    2014 Jeep Grand Cherokee SRT
    1977 Steyr-Puch Pinzgauer 710M
    2 Timothy 1:7
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Check the seal behind your front sprocket.
    Sep 2012
    TX
    188
    Do I need to remove the cover over the front sprocket to access it?
    Gone - 2006 TW200
    Gone - 2014 CB1100
    2 Timothy 1:7
    Sep 2011
    2,431
    Yes, you'll have to remove the cover to get to it. I'd pull the skid plate off and try to get a look from underneath it first. It may be something else, but that's a good place to start.
    Stanwood,Wa
    1,880
    " Is this common for this gasket between the crankcase pieces to leak? Bike is an '06 with ~6000 miles. I cannot find the replacement gasket to save my life if this is the issue. "
    Yes this a problem with the 06' and some 07'. You can replace it with a 2010 or newer gasket. There is a sticky in the Tech section for this fix.
    I got a quote for $400.00 for the dealer to fix, others on here say it takes a few hours but can be done by yourself.
    Tracy
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    Mar 2011
    Gobles, michigan
    1,824
    Quote Originally Posted by goldenhtr View Post
    Tracy
    Hmmmmmmmmmmmmmmmmmmmmmmm.. I got a quote from my dealer of $250.oo I guess that wasn't to bad then... Both my 06 and wife's 06 has the same small leak........ It's so small I haven't even bothered to fix it yet......... OMM.
    Stanwood,Wa
    1,880
    That is a good deal. If it was only $250 I would have it done. But the leak is so small that I never see the oil level change, and no drops on the floor just the engine case.
    Gen:27:3
    -Ronald Reagan
    Sep 2012
    TX
    188
    Tracy
    I might just be being stupid, but I don't see the thread. Just to clarify, this is *not* the base gasket between the cylinder and crankcase. It is the gasket between the two main pieces of crankcase as shown in this diagram...
    http://www.yamahapartshouse.com/oemp...30b6/crankcase
    As you can see, no gasket is listend for this
    I have pulled the skidplate before and it was already all mudded up. *looked* like it was coming from between the two cases. The only thing that leads me to believe this is not the issue is that I only get 3-4 drops (or the puddle if I rode for a while) after I park it for 1 day or 4 days. So, once it's been off, the leak stops. I don't know if this is because the oil thickens or if it's because the leak is higher.
    Kyle
    Gone - 2006 TW200
    Gone - 2014 CB1100
    2 Timothy 1:7
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Have you attempted to retorque the bolts?......no-doubt,replace the oil filter cover o-rings and others.
    Sep 2012
    TX
    188
    Quote Originally Posted by frog13 View Post
    I'm actually looking at the valve cover gaskets (adjusting valve lash!), oil change gasket set, and TDC gasket set! They came in today Re-torquing all the bolts are on my to-do when I fix all these other gaskets. I'm also changing out the clutch here soon, so that gasket is getting changed soon as well.
    Gone - 2006 TW200
    Gone - 2014 CB1100
    2 Timothy 1:7
  1. Oil Leak
    By ldw72120 in forum Technical Help
    Last Post: 02-25-2013, 08:49 PM
  2. Oil Leak
    By Senior Dirt Dog in forum Technical Help
    Last Post: 08-03-2012, 09:48 PM
  3. oil leak from where
    By jerz006 in forum Technical Help
    Last Post: 07-07-2012, 06:00 PM
  4. Oil Leak
    By B-dub in forum Technical Help
    Last Post: 08-09-2011, 01:19 AM
  5. Oil Leak
    By Mike Mecredy in forum Technical Help
    Last Post: 07-19-2011, 06:15 PM
how to change valve cover gasket yamaha tw200
klr650 oil leak neutral sensor
