Flatslide Carb on 2019 TW, Float bounce?
Results 1 to 8 of 8
Like Tree4Likes
  • 1 Post By ThePhotoFred
  • 1 Post By Ken
  • 2 Post By jbfla
Thread: Flatslide Carb on 2019 TW, Float bounce?
    Junior Member ThePhotoFred's Avatar
    Jun 2019
    Colorado
    3
    I'm a whiz on the old Mikuni carbs, but this flatslide is a bit different. I have 2 2019 TW 200's with less than 300 miles on them. Bikes run good at all elevations from 4500 feet to around 11,000 feet as long as they are on some what level and smooth roads and trails. Once the bikes get on steep grades that are covered in rock or wash board, they lose power and won't hardly run. Hit it and git it is the only way they will run. I pulled the plugs and confirmed they are running way rich and flooding out. Could float bounce cause this or is jetting the issue? Both bikes are doing the same thing.
    Thanks in advance.
    Ken likes this.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,399
    Not a flat side carb on on 2019 TWs....Teikei CV carb.
    Most likely a jetting problem. Several threads on high elevation jetting.
    https://www.tw200forum.com/forum/tec...e-jetting.html
    jb
    Ken
    Ken is online now
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,932
    Welcome. I have an old 1993 so I can't help you on the carbs, also I am at sea level.
    ThePhotoFred likes this.
    1993 TW200 just over 46,000 miles
    Member kangaroo's Avatar
    Jun 2019
    SF Bay Area, Cali
    52
    That’s why flatslides make great racing carbs. Constantly dumping as much fuel as possible. Day to day, youre always running rich.
    2006 Tw200
    Jun 2019
    Colorado
    3
    Thank you.
    Jun 2019
    Colorado
    3
    My owners manual says its a Mikuni 28mm, but you are correct as I just found out. I'll have to research this particular carb as I'm not familiar with it. Mikunis and Amals are more what I am used too.
    Jun 2019
    SF Bay Area, Cali
    52
    I have keihins on my R1 with a Ramair setup. It had a rep for being a complete pain to setup once upon a time.
    2006 Tw200
    FL. GA, NC
    2,399
    Quote Originally Posted by ThePhotoFred View Post
    ...... I'll have to research this particular carb as I'm not familiar with it..........
    https://www.tw200forum.com/forum/tec...ification.html
    jb
    Purple and Xracer like this.
