Gunk on Chain
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree13Likes
Thread: Gunk on Chain
    Mar 2019
    Austin Tx
    251
    Gunk on Chain
    So I just cleaned and lubed my chain yesterday afternoon after a day in the dirt and mud.
    Today I am seeing this junk on my chain. I’ve only ridden to work and back. It rubs off. Assuming dust and dirt sticking to my lube? It’s pretty tacky stuff.
    I’ve noticed this same stuff previously, but I guess never this soon after cleaning. I’m trying to be way more diligent than I previously have been with chain maintenance. Should I stop worrying or get some new lube?
    2019 Yamaha TW200
    - DGv2 Slip On
    - Custom Oil Cooler
    - Manracks Seat Rack
    - Ricochet Skid Plate
    - Oversizzed Footpegs
    - Cycra ProBend Handguards
    1973 Yamaha RD350
    Hailey, ID
    3,377
    What kind of lube? O-ring chain or normal? It looks a lot like rust, which doesn't make much sense so soon after......UNLESS the rust was already there inside a stock chain and the lube worked it loose, or you power-washed the chain. (Don't EVER do that!) Do yourself a favor and get a Z-ring chain if you don't already have one.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member YamTW87's Avatar
    Mar 2017
    Greece
    149
    You can rub it off by hand or you need to scratch it with something hard?
    It looks like rust to me,but it't too much rust to form in such a short period, I think............
    2007 Suzuki V-Strom 650
    Senior Member TeeDoubleUTwoHundred's Avatar
    May 2019
    Ontario, Canada
    194
    Is it the same colour as the mud you were riding in?
    YamTW87 likes this.
    2017 TW200 -> Hand Guards-Chain-Foot Pegs-Skid Plate-Shifter-Grips-Mirrors-Fuel Filter-Fender-Levers
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,395
    i would try a different lub, one for off road use. the lub for road use is more tacky and attracts dirt. i use a wax spray, but it builds up after a while and is hard to clean
    Trail Woman likes this.
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Mar 2019
    Austin Tx
    251
    So it's similar to the mud color I was riding in, but not exactly. Also when I have previously noticed this same color, I hadn't ridden in that mud/spot. The stuff seems to rub off easily with my fingers—no scraping necessary. It's very greasy on my fingers when I do so. Tis odd. I've been pretty good about cleaning the chain after any dirty/muddy adventures, and even just through normal riding. I mean, at least once every couple of weeks I am cleaning and lubing the chain. The rear sprocket also has some dark junk building up since then as well. Maybe I put too much lube on to begin with, and it's causing a ton of build-up?
    It's BelRay Chain Lube. I believe it's just for standard chains, but I don't remember seeing anything specifically listed on the bottle—I've had it for years though.
    I don't power-wash it, just use the Jet/Shower settings on my standard hose. I guess it's possible the "jet" may be a little too much for the chain? Though I believe this was the first time I actually used the hose/jet setting directly on the chain and I had seen the stuff build up previously as well...
    I'm thinking I may find some different lube, clean and start again. If it continues, I guess I'll upgrade the chain.
    2019 Yamaha TW200
    - DGv2 Slip On
    - Custom Oil Cooler
    1973 Yamaha RD350
    Mar 2015
    Ynys Môn
    4,593
    Well, it “could be” that having introduced your stock chain to a world of water (which doesn’t take a lot of doing – streams, puddles, hose pipe etc), it’s now puking up the rust from inside the rollers, which combined with the ever present dust, (and the fresh lube), is now sticking to the outside and discolouring it
    It might last another five yards, it might go on for thousands of miles – but I’d suggest a new “X” ring or “Z” ring chain would be a “wise investment” at this point
    Say goodbye to that old chain, and with it, you say goodbye to constant adjustment, cleaning – the money saved on lube alone would pay for it in the long run. But please, say goodbye to hitting the chain with a hose first. Any chain relies on oil, all water does is complicate things – all you’re doing is filling the gaps in the OEM rollers with water
    An X ring chain is designed to stop this from happening ……
    tylermoney and YamTW87 like this.
    - Hidden Content
    Mar 2019
    Austin Tx
    251
    Right on. I mean, I kind of figured that is where this was going. Thanks all for the POVs. Appreciate the time. I'll try and remember to update this post when I am officially new-chained
    Purple and Darth like this.
    2019 Yamaha TW200
    - DGv2 Slip On
    - Custom Oil Cooler
    1973 Yamaha RD350
    6,985
    Can't go wrong with a new chain and sprockets.
    Mar 2019
    Austin Tx
    251
    Well, I've only had the bike since February. Do I really need new sprockets already as well? I mean, if I was planning on adjusting the teeth, it would make since to do it now, but if I don't want to spend the $$ ... wondering if it's necessary. I can't imagine they have that much wear on them yet?
    2019 Yamaha TW200
    - DGv2 Slip On
    - Custom Oil Cooler
    1973 Yamaha RD350
