Valve adjustment gone wrong?
Results 1 to 5 of 5
    Member AKTW's Avatar
    Jul 2019
    Prince of Wales Island Alaska
    36
    I followed tdubskid video on valve adjustment..but it didn't end well. First problem I had when adjusting the intake. I tried tightening it back up, my torque was set correctly but it stripped the tippet, just deformed the threads. I was able to get a new one and replace it. I had it adjusted .003 intake, .005 exhaust. Started it up, idle fine, reved it up fine, put it in first (I have a tach) and ran fine all the way up to 6k rpm. Shifted to second and all of sudden at 3500RPM or so it sputters and won't rev any higher. In neutral it will rev up but in second it sputters any ideas?
    Senior Member Apolloha's Avatar
    Dec 2018
    222
    Did you replace the nut and the stud? Got to replace both components with threads when you strip them. Sounds like it has opened up the clearance. You won't get full cam lift. Thus not as much air flow to the cylinder.
    2017 Apollo 250
    2018 Yamaha TW200
    1978 Suzuki DR370
    Jul 2019
    36
    Quote Originally Posted by Apolloha View Post
    Although I deformed the tippet (is that what you are referring to as the stud) When I replaced it I put the nut back and checked clearance. When I put the nut on, it threaded the new stud (tippet) fine.
    So we are on the same page exhaust clearance: .004-.006 and Intake .002-.004 is that correct?
    Mar 2015
    Ynys Môn
    4,594
    - Hidden Content
    Hailey, ID
    3,377
    Quote Originally Posted by AKTW View Post
    Although I deformed the tippet (is that what you are referring to as the stud) When I replaced it I put the nut back and checked clearance. When I put the nut on, it threaded the new stud (tippet) fine. ...
    There have been instances of soft metal in quite a number of TW studs, bolts, nuts, and so on over the years.
    On such a critical component that costs so little it's nuts not to replace both at the same time. Impossible to tell if stripping the tappet threads also weakened the nut threads.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
Tags for this Thread
