1992 tw200 carb ?
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Like Tree16Likes
Thread: 1992 tw200 carb ?
    Junior Member mike ohler's Avatar
    Jul 2019
    15
    1992 tw200 carb ?
    Can I use a post 2000 carb on a pre 2000 bike? If so are there any modifications needed? thanks
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,406
    Quote Originally Posted by mike ohler View Post
    Yes. You will need the manifold joint and the rubber air box boot from the 2001 and newer TW for a seamless fit.
    jb
    Darth likes this.
    Jul 2019
    15
    Hey, Thanks good to know if cleaning the old one does not work, Just picked this bike up the other day, definatley not getting enough fuel to run, it wants to start but barely. alot of knowledge on this forum. thanks again,
    Mar 2015
    Ynys Môn
    4,635
    Try to get the old one working - in addition to the above (which are expensive from new) - you will find the cables leading in from the wrong side. The cable situation is an easy work around. The flat slider on the older models was superior in my opinion .....
    jbfla likes this.
    - Hidden Content
    Jul 2019
    15
    Got it running cleaned carb and tank, It will Idle with the choke pulled out but that is it. I am going to order a rebuild kit and try that. If I was to buy the new 2001+ carb is there any extra hoses or ports I would need to plug? Seems like I read that some where. thanks again
    Jul 2019
    15
    the manifold boot I have seen on ebay and amazon are listed to fit 1987 to 2017 and appear to be the same as the one I have. And I see no air box boots any where un less you buy the whole box which looks to be the same
    Jun 2017
    Milwaukee, WI
    1,294
    I got my boots from Partzilla. The boot on the engine side has a small nozzle that needs to be capped or plugged.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,130
    There is no benefit at all by going from the old style carb to the newer style. Carbs is Carbs and one is no better or worse than the other. You said you have it cleaned but you do not say if you replaced the usual suspects inside of it so it will run right. The float valve and seat are the most common of issues IMO. Unless the jets are crudded up from nasty fuel corroding them there is usually not much reason to replace them. Check the enriching diaphragm to make sure the piston is moving freely and soak the stripped body in either Berrymans carb cleaner or run it through numerous cycles in an ultrasonic cleaner with some Pinesol. The boot from the air box to the carb is another of the usual suspects because they shrink and get very hard so they no longer form a tight seal. Any air leakage there can and will cause problems. Just buy a new boot and make absolutely sure the seal is air tight. The real problem with swapping from the old to the new carb is the diameter of the carb intake and engine side are different so you must change the boots to fit the new carb and then reroute the throttle cables. Not worth the trouble or expense IMO. A 2000 TW against a 2001 TW with their respective different carbs both correctly tuned do not run any better than each other so you get nothing by going to the newer carb.
    1987 Yamaha BW350 Big Wheel
    Jul 2019
    15
    do you happen to know the part numbers?
    Jun 2013
    Forestburgh, NY
    8,130
    Here! https://www.partzilla.com/catalog/ya...00h/carburetor
    Here https://www.partzilla.com/catalog/ya.../tw200h/intake
    Purple likes this.
