Carb hose purpose
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Dirtjet
Thread: Carb hose purpose
    Junior Member Dirtjet's Avatar
    Feb 2017
    Carefree, Pine AZ
    20
    Carb hose purpose
    Iím changing out the carb, hoses, filter, petcock and air filter on my 2002 TW. I have a fuel leak on the carb and petcock and Itís been 10 years since I installed the hoses so itís time. My question is there is a hose coming from the rubber boot between the carb and the intake on the engine. The hose runs up under the fuel tank almost to the handlebars and then it has a plug in it. Should it have some type of a breathable one way filter? The bike runs fine so I should probably not worry about it but I am curious. Thanks. 0641E334-2297-42F8-B18A-606DE386ECC0.jpeg2D7C7CDE-5A33-40B6-B498-76F8B9A2EC0C.jpeg
    buellzebub likes this.
    Jun 2017
    Milwaukee, WI
    1,285
    See post #4 ....
    https://www.tw200forum.com/forum/per....html#post7588
    When I replaced the carb on my 89 with a newer style CV carb (knock-off from China) and boots, I capped the tube at the boot and that bike ran as well as my other stock bikes. I believe that long tube connects to the charcoal canister on California TWs.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Senior Member Donzo's Avatar
    Oct 2016
    NorCal
    773
    I have the same plugged tube it was the cannister as BF said so you can ignore it
    Feb 2017
    Carefree, Pine AZ
    20
    Thanks.
