Silver/Gray Engine Paint?
Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By Xracer
  • 1 Post By jeepster09
Thread: Silver/Gray Engine Paint?
    Mar 2017
    Yuba City, CA
    394
    I'm putting an '03 TTR225 engine in my friend's '05 TW200, using one of Placerlode's countershaft extenders.
    The TTR engine is a silver/gray color (like the TW engines from '89-'03), but my friend's TW engine is black.
    The problem is, I've got to use the TW left side cover on the TTR engine, and I'd like to make it match (somewhat, at least).
    I've got a spare side cover that I've been trying different paints on, but I can't seem to find a good match.
    Have any of you found a good match for Yamaha's silver/gray engine paint?
    Or... do any of you have a silver/gray TW side cover with good paint you can part with (or maybe trade for a black one)?
    Thanks, guys!
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    Try a good hobby shop. I've often found hard to find color matches there.
    CJ7Pilot likes this.
    Senior Member jeepster09's Avatar
    Nov 2010
    Twin Cities Minnesota
    263
    I have used Krylon Silver wheel paint, matched pretty good.
    "Life Member NRA"
    Mar 2017
    Yuba City, CA
    394
    Jeepster called it!
    I ended up using Duplicolor HWP102 Graphite wheel paint.
    It's a little bit darker... but not obnoxiously so. Also, there's darker paint underneath, so maybe a gray primer base coat would lighten up the finished product.
    Unfortunately, it turns out I can't use it. It's a 1989-2000 side cover, so it won't work with my friend's 2005.
    Does anyone want it? It has a new SKF sealed countershaft bearing installed!
