5 HP Piston kit
Results 1 to 5 of 5
Like Tree11Likes
  • 3 Post By Ken
  • 4 Post By RaZed1
  • 4 Post By bartruff
Thread: 5 HP Piston kit
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,932
    5 HP Piston kit
    Has anyone tried this piston kit? This one is advertised as Vito's. I couldn't get the link to copy on Ebay.
    YAMAHA BLASTER SUPERSTOCK PISTON KIT 67MM BORE SIZE ADDS 5 + HORSEPOWER
    Some of these pistons look like they are for 2 strokes while some look like they are for 4 strokes. I don't know about TW200 compatibility.
    Last edited by Ken; 07-28-2019 at 06:52 PM. Reason: delete post, not compatible from what I see.
    1993 TW200 just over 46,000 miles
    Aug 2016
    Houston, Texas
    1,932
    Ok, I saw this is not compatible.
    Now for the crazy. I was reading about the Mazda Skyactiv-G which the 71mm piston has a compression ration of 13:1. Do we have any brave souls who would dare to experiment and see if they could match it up to a TW rod? They also have a 14:1 cr but is a much bigger bore.
    Senior Member RaZed1's Avatar
    Oct 2015
    294
    We're talking apples to broccoli here.
    2 stroke and 4 stroke pistons are not interchangeable. I mean the bore might match up and technically fit, but they are designed for completely different lubrication. 2 stroke pistons are not meant to control oil and are designed to allow oil (from gas) to lubricate the piston walls and rings, where 4 stroke pistons have oil control rings that "scrape" the cylinder clean so oil is not allowed into the combustion chamber. 2 strokes only have compression rings. You can probably see how mis-matching this would not work, at least not for very long.
    Plus, other factors go into determining effective CR, not just the piston. You could deck down the TW's head, leave the piston stock, and effectively increase the compression ratio since you decreased the head area. The piston's travel has the same displacement but it's now being shoved into a smaller area, so the ratio between BDC and TDC has changed. The Mazda could have an extremely tiny head volume and a dished piston, which when put in the TW would actually lower it's CR despite the engine it was poached from has a higher one. You'd also have to consider valve lift and piston clearance based on how tall the piston is. Point being a lot more factors go into it than just grabbing a piston with the same bore, from an engine that had more compression.
    Ken, Xracer, white mule and 1 others like this.
    Senior Member bartruff's Avatar
    Oct 2018
    Wenatchee Wa.
    196
    My butt would not notice a 5hp increase....but my bank account would....
    Senior Member Tiny-Wheel-200's Avatar
    May 2013
    Wasilla, Alaska
    726
    For offroad stuff I'm always going at half throttle so extra go has little value to me. On the road it might be different.
