Rear Brake trouble
Results 1 to 6 of 6
    Senior Member TdubOhio's Avatar
    Feb 2012
    Ohio
    100
    2012 with about 4500 miles on it.
    Felt a "hitch" in the rear brake while I was out.
    Getting back home and taking a look at it just now, and something is def wrong.
    The arm that comes off the drum does not spring back anymore, no matter if I have turned the wing nut down tight, or loosened it up all the way.
    Basically, when I push down on the foot pedal, the arm looks like it stays in a forward position after I pull off.
    The brake isn't locking up, at least not violently... the pad may be rubbing I guess, but not noticeably.
    Also, occasionally, when I was using hands to move it back and forth, I would feel that "hitch" again, like something is catching.
    I have no idea what is up.
    Brake cleaner and WD40 didn't change a thing and thats as far as I've gotten.
    Got to head off to class in a minute, but looks like this is gonna be my weekend project.
    Could that rear pad have worn out in less than 5k?
    My front pad looks like it has tons of life left in it...
    Also, on the backside of the brake drum arm there is an arrow indicator sort of gauge... never noticed it before... assume its important, lol.
    Desert, SoCal
    7,369
    The gauge is a wear gauge. There's a pointer on it which indicates how much beef is left on your linings. If you push down on the brake pedal and the pointer is near the end of the scale it's time for new shoes.
    If that's not the case then most likely your brake engagement cam shaft has become corroded inside the backing plate and needs to come out.
    In any case you'll need to remove the rear wheel to get to the backing plate. Remove the brake arm and pull the shaft that passes through the backing plate out from the inside of the backing plate. It may take a bit of lubrication and patience. There's an o-ring on the shaft which can tear if you force it out.
    Clean the bore in the backing plate, as well as the shaft. It's probably coated with some pretty stubborn, hardened black stuff. Put some grease on the shaft and o-ring then smear it with your fingers until it's only a barely visible coating. Same with the flats on the cam. Re-insert the pin and make sure it rotates easily in any direction, then if your brake shoes themselves are still good and your brake springs are still intact, reassemble everything, adjust your brakes and yer back in buisiness.
    Feb 2012
    Ohio
    100
    Yep... gonna be a long weekend...
    Thanks, lizrdbrth
    Desert, SoCal
    7,369
    Danwray just posted this on another thread. Another, simpler possibility:
    ........""FYI, I found that the little plastic part that the spring surrounds on the rod going from the pedal to the drum was becoming unseated. Instead of sliding on the rod, it would pop off and clamp the rod. Thats the sticky feeling i was experiencing. Just in case anyone else was experiencing this.""
    Feb 2012
    Ohio
    100
    Well, Lizrdbrth was correct the first time... it was just the brake cam shaft completely seized up in there.
    Had to order another one and another entire plate as well, cause nothing would get that cam shaft out of there.
    And yes, I waited this long to fix it, because I am clearly an idiot.
    I will say that the front brakes have done the job well for my daily commuting needs...
    Now, after having just completed the rear... the fronts clearly need replacing...
    So, back out into the heat it is!
    Senior Member tinman tim's Avatar
    Jan 2012
    northeast ohio
    503
    glad to hear you got it figured out. If I may add 1 thing, it would be to use never-seize on all the parts sparingly.
  1. trouble with tail light install - DRC Edge Brake Light
    Last Post: 07-13-2017, 08:36 PM
  2. Rear brake ider
    By xdac in forum General Discussion
    Last Post: 04-27-2014, 07:23 PM
  3. sticky rear brake
    By danwray in forum Technical Help
    Last Post: 03-01-2013, 08:32 AM
  4. Rear Brake Squeal
    By dhendric in forum Technical Help
    Last Post: 09-20-2012, 09:57 AM
  5. Rear Brake Lever
    By FnMag in forum Technical Help
    Last Post: 12-20-2011, 12:43 PM
