1987 carb questions.
Results 1 to 10 of 11
Like Tree13Likes
Thread: 1987 carb questions.
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    378
    Have a kit coming with stock jets as well as all the other assorted parts needed. Will be riding in the 6-700 foot above sea level range. At least for the most part. So any reason to change the jetting? If so what jets would be better? Mind you I am not as young as I once was. Won't be wailing on the old girl like back when. And any longer road trips will be on the bigger bike. Perhaps an occasional short hop on the highway for an exit or two. Mostly around town and light trail riding.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Mar 2017
    Yuba City, CA
    394
    Although the stock jets will run fine, they do run a little lean at lower elevations.
    The '87 I got from Little Tommy has a stock carb,which was professionally rebuilt and re-jetted for lower elevations (Seattle), and it runs great here in Northern California (Sacramento Valley)!
    Without taking it apart, I can't tell you exactly what was done to it... but if I were trying to reproduce it, I'd start with one size larger main jet, shim the jet needle, and properly adjust the idle mixture screw.
    You need a good baseline though, so maybe just install the kit as-is, and see where you want to go from there.
    Have fun!
    GOF likes this.
    Spokane, Washington
    17,423
    Quote Originally Posted by CJ7Pilot View Post
    Have fun!
    It was more than that, but it's top secret...
    elime, Purple and CJ7Pilot like this.
    1st John 1:9
    John 3:16
    John 3:17
    6,985
    A brand new #114 high speed jet can works wonders on a carb that old.
    Jets wear out. The hole in the center gets bigger with use and age. Don't be fooled thinking the old jet is OK just because it looks OK. Replace it. Set the idle mixture screw to around 2.5 turns out, adjust to your liking, thoroughly clean the inside of the carb and you should be good to go.
    I have tried a couple of different carb kits and found them both to be junk but that was a few years ago and maybe they have improved. Good luck and report back your results.
    CJ7Pilot and GOF like this.
    Mar 2017
    Yuba City, CA
    394
    Well, now I might have to peek inside....
    littletommy likes this.
    Spokane, Washington
    17,423
    It if ain't broke, don't mess with it!! It was and still is the fastest stock 87 on the forum!!
    CJ7Pilot likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,094
    700 feet above sea level is nothing! I live at 1400 feet above and still nothing as far as the carb and jets are concerned. Get up in the mountains where 6,000 and above and you might want different jetting. All "Carb Kits" are not created equal so it will depend on which brand of kit you bought. I hear good things from members who bought the Pro Cycle kits and bad things from those who bought the Ketster and other low quality kits. Yamaha proper does not sell a "KIT" for rebuilding these carbs but they do sell all the internal parts separately and I stick with original OEM stuff whenever possible.
    jbfla and GOF like this.
    1987 Yamaha BW350 Big Wheel
    Dec 2018
    Buffalo, NY
    378
    Well, We shall see what I get when the kit arrives. I am sure that it will be an improvement over the fuel dripping on the floor.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Jun 2013
    Forestburgh, NY
    8,094
    Quote Originally Posted by GOF View Post
    Fuel not shutting off is a very common issue almost always related to the float valve sticking. I have seen this in brand new bikes and newly rebuilt carbs with new float valves freshly installed. A prudent preventative for this is to always shut the petcock off while not in use. Sometimes a light tap on the side of the carb will free the sticking valve so it does shut off. When your new parts arrive make sure the float level is set top the correct height and the needle is installed right and freely moving. The tab you adjust the height with could have a slight burr or deposit on it so be sure to inspect it closely. This is one of those unsolved mysteries around carbs and I installed a brand new OEM carb once and took the Tdub for a cruise. All was running fine and with no issues at all. I then had the bike on the lift to adjust the chain and do some other checks and had no leaking fuel from the overflow. The next day I went to the shed to find half my fuel leaking onto the floor. Hard to say why but I had not shut off the petcock and I suspect some atmospheric change caused the float valve to stick. I tapped the side of the carb with the rear of a screw driver and it immediately stopped dripping. When you get the old valve seat out take note of the fine screen above it as this is often where crud gets caught so it does not enter the carb float bowl.
    GOF likes this.
    Dec 2018
    Buffalo, NY
    378
    I have rebuilt many carbs over the years. But few on bikes. I had this one apart to clean whatever crud may have built up over all the sitting and whatever rust may have found its way from the tank. Found a few flakes in the filter screen at the inlet. I suspect that the 32 year old seal on the seat didn't like being disturbed. In 15 minutes i developed a wet spot of fuel under the bike a little over a foot in diameter. Other than that it was running well. At least for the couple of blocks I rode it. So I figured I'd replace the gaskets and seals and needle and seat. Started this thread wondering if changes to the jetting might be worth while.
    1988 Suzuki Savage
    1987 Yamaha TW200
