Cam chain adjuster 1987
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Ken
Thread: Cam chain adjuster 1987
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    378
    I understand these are manual adjusters. Anyone have a good tutorial on checking/adjusting it?
    1988 Suzuki Savage
    1987 Yamaha TW200
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,932
    The inset dimension on the cam adjuster is so small of an adjustment I always just make sure that the cam adjuster is slightly negative. If you want to get it exact you can use a caliper and measure the depth to spec. Basically it is, remove the plastic cam adjuster cap, loosen the locknut, turn the adjuster until spec is met, tighten the locknut back up, then replace the plastic cap. Make sure you only tighten the plastic cap barely beyond snug, you don't want to strip it. Mine is a 1993 so please double check for any differences.
    GOF likes this.
    1993 TW200 just over 46,000 miles
    Dec 2018
    Buffalo, NY
    378
    Thanks Ken.
    1988 Suzuki Savage
    1987 Yamaha TW200
