Whaaat? - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree15Likes
Thread: Whaaat?
  1. #11
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,048
    Both front marker/blinkers should come on as well as the headlight as soon as you switch the key to on. If the bulb on the right is good but not coming on then check behind the cowl for a lose bullet connector. The dealer likely has nothing to do with this as these bikes come from the factory with all the electrics hooked up unless the handle bars were removed for some odd reason. I suspect you have a burned or broken filament in the right side bulb.
    1987 Yamaha BW350 Big Wheel
  2. #12
    Junior Member Mesquite's Avatar
    Jul 2019
    Mesquite, Nevada
    4
    Considered yourself bonded. Mine does exactly the same thing. Based on previous bikes, I have assumed it's a burnt out filament in a bulb, but I haven't taken it on yet.
    I'm also wanting to replace the taillight assembly and rear turn signals so have been waiting to do it all as one job. It's good to practice hand signals!
  3. #13
    Junior Member deadguy's Avatar
    Jul 2019
    Lucerne Valley
    5
    The bulbs are OK but I found a blue wire with a male end that isn't connected to anything, and I can't see anywhere for it to plug in behind the cowling.
    Darth likes this.
  5. #14
    Jun 2013
    Forestburgh, NY
    8,048
    Quote Originally Posted by deadguy View Post
    Just a guess from poor memory but if you trace the wires from the side that works you might find where that one plugs in has a double female connector in one of those rubber boots. One filament in each bulb comes on and stays on when the key is on so both of the third wires on the front blinkers could be plugged to the same connector.
    MtnMan75 likes this.
