Whaaat?
Results 1 to 10 of 14
Like Tree15Likes
Thread: Whaaat?
    Junior Member deadguy's Avatar
    Jul 2019
    Lucerne Valley
    5
    Whaaat?
    Got the dub a week ago and I'm trying to bond. When I turn the ignition on the left front turn signal lites up, doesn't blink, just stays on, everything else works OK. I realize this is a minor thing, and not worthy of a 40 mile trip back to the dealer, but it's an irritation none the less. Should I pull the bulb, wait till it burns out or what?
    jtomelliott49 and Darth like this.
    Mar 2015
    Ynys Môn
    4,571
    They all do that .....
    (you have a short)
    jtomelliott49 likes this.
    - Hidden Content
    Pleasanton, CA
    5,720
    Both front signal lights should come on, they are running lights and should also blink when the turn signals are used.
    Jun 2017
    Milwaukee, WI
    1,267
    I’ve never had to open one. Are they dual filament?
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 10K miles, decent condition
    04 in great condition
    BC
    623
    The front turn signals are three-wire, indicating a double filament...just like the rear running/brake light
    The rear signals are two wire...they only flash with the turn signals.
    Darth likes this.
    2008 TW200
    Southwest corner of BC Canada
    Hailey, ID
    3,338
    Standard automotive dual filament but I forget exactly which one since I switched to LEDs. Most likely the right filament died of infant mortality. You should be able to see the broken filament or use a test lamp. (Or swap bulbs if you don't have many tools.) If that's not it, the connectors could be loose. They are pretty easy to see after you remove the cowling.
    Remember that ALL TW screws are JIS standard, not Phillips. The screwdriver in the tool kit should fit the lens cover.
    Darth likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    18,714
    1157 is the bulb's nominal designation. Available in both filament and LED. Both are also available in various wattages. I say get the brightest whether it be filament or LED.
    Darth likes this.
    Jun 2016
    New Rochelle, New York
    1,766
    Sounds like your "right" turn signal or at least the right running light is not working. Left is doing what it's supposed to do... light up when you turn on the ignition.
    Check your wiring and then lamp itself. Call the dealer (is this a new bike) just to let them know in case it's something more involved.
    1995 BMW K75 (Elec Start)
    Senior Member Motoad's Avatar
    Oct 2014
    Creston, BC
    547
    Mine came from the dealer with them reversed. Apparently they are staffing that outfit with people who have been fired from MacDonalds.
    Senior Member NumberThree's Avatar
    124
    My right hand one burned out 3 or 4 times. Replace the bulb as a first step.
