How does my plug look?
Results 1 to 3 of 3
    Member beefcake morris's Avatar
    Dec 2012
    Jacksonville, Fl
    99
    Hey guys bike runs great, starts up without the choke. So what do you think about my plug?
    Location Jacksonville Fl
    130 main
    5 shims (real ones)
    "I am simply a guy trying to master a very simple machine with very complex dynamics"
    MSF Rider coach
    Aug 2011
    Cayce, SC
    3,109
    If you want to get a more accurate look you need to put in a new plug, run in it for about two minutes at wot and then pull it. This plug is showing mixed results. The different ranges- pilot, needle and main will show different results so with the change you made a wot test will tell you what you want to know.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Senior Member niqhowie's Avatar
    Oct 2012
    New Mexico
    123
    The metal probe above the electrode indicates that it is running lean still, WHITE AND YELLOWISH IS BAD. Yours show both white and black portions. Your photos are hard to see and dont show the electrode either, It should look like a tanish color! But PALMSTATECRAWLER is right on when he says a new plug is best to determine an accurate reading.
    "Peace be the journey"
    MY BIKE BUILD- Hidden Content
    -2012 tw200
  1. Magnet Oil plug
    By Woodi23 in forum Performance and Customization
    Last Post: 04-02-2013, 03:32 PM
  2. Replies: 2
    Last Post: 07-21-2012, 12:44 AM
  3. Spark plug
    Last Post: 05-09-2012, 08:19 AM
  4. Spark plug pic
    By mjlater in forum Technical Help
    Last Post: 03-24-2012, 05:13 PM
  5. wtb OIL DRAIN PLUG
    By rvtjonny in forum TW200 Classifieds
    Last Post: 02-06-2012, 07:35 PM
