More metal in oil woes
Results 1 to 10 of 16
Like Tree9Likes
Thread: More metal in oil woes
    Junior Member Pedal-E's Avatar
    Aug 2019
    Seattle, WA
    3
    Lurker now a member. Picked up a 2004 with 2800 miles and most were on road. Bike has seen limited use in last few years. Changed the old to find what looks to be aluminum flakes in the strainer and filter. Ideas on the source? I'm baffled at the presence of flakes at this mileage.
    2004 TW200
    2018 RRS390
    Pleasanton, CA
    5,787
    Don't sweat it, unless you know for sure that the oil has been changed 3 or 4 times before you got the bike. That is pretty typical for the first few oil changes.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,491
    Yaaaaaa it drives me crazy every time I change my oil and it never seems to end.
    Senior Member Apolloha's Avatar
    Dec 2018
    252
    Same here. Scared me on the first oil change. I had to go on here to discover its normal.
    Second time was way better. Third time was clean.
    2017 Apollo 250
    2018 Yamaha TW200
    1978 Suzuki DR370
    Hailey, ID
    3,409
    Probably due to the PO not changing the oil, but I would look again in 500 miles. No need to change the oil then unless the filter has that much metal again. For most people 1,000 mile intervals are reasonable.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member RaZed1's Avatar
    Oct 2015
    299
    That's really not that uncommon, especially on the first few oil changes, any who knows when/if the previous owner changed the oil. I wouldn't worry about it. TW engines "blowing up" are virtually unheard of, and can almost always be traced to someone putting the wrong oil filter in, which wipes out the cam lobes and eventually locks up the engine via the cam bushings seizing. Make sure the filter has 4 small holes in one side. If there are only 2 or none, it's the wrong filter. There's been numerous cases of people getting the wrong filter at the dealer or the wrong filter in the right box.
    GOF likes this.
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    985
    The chunks will get smaller with each oil change
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    Aug 2019
    Seattle, WA
    3
    Thanks for all the replies. I will try to ignore my inner voice saying '"metal in oil is not normal" and just keep riding and changing the oil. The filter I took out and the replacement are both the 4x hole variant..sorted that with the help of the forum.
    GOF likes this.
    2004 TW200
    2018 RRS390
    Hailey, ID
    3,409
    Metal in the oil is normal during break-in is normal for these old technology engines....it is NOT normal after 1,500 miles!
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    378
    Assuming the oil changes were done in a timely manner.
    1988 Suzuki Savage
    1987 Yamaha TW200
