Different chain options, BikeMaster Heavy duty?
Results 1 to 9 of 9
Like Tree4Likes
  • 1 Post By BikeNbowHNTR
  • 1 Post By GaryL
  • 1 Post By stagewex
Thread: Different chain options, BikeMaster Heavy duty?
    Member BikeNbowHNTR's Avatar
    Jan 2018
    Vancouver Island
    36
    So after a trip into the bush which involved my chain piling up and breaking a link ( I will post about that in the Adventure section...) I am in need of a new Chain.
    I have ordered a couple of Sunstar 428 front and rear sprockets (14/50) and trying to decide between a few chains. BikeMaster has a "heavy duty" version in the 122 tooth that I
    am thinking about.
    Either that or the DID or Standard BikeMaster.
    Any experiance with this "heavy Duty" Chain?
    TonyT likes this.
    2009 TW200, stock, so far...
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    958
    This would probably be the last one you would need https://www.amazon.com/D-I-D-Pro-Str.../dp/B0068FTO5S
    I think this is the one I bought a few years ago. Made especially for the TW200 https://www.amazon.com/dp/B0787DP6Y8..._t3_B0068FTO5S
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    GOF
    GOF is online now
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    367
    I went with a DID o-ring chain. It's a bit longer than I need. I'll just lop off the excess.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Jan 2018
    Vancouver Island
    36
    Thanks! I will check those out!
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,047
    You can't go wrong with the DID VX chains and the correct time to add a new chain is when you are replacing the sprockets with it. This way they meld together and last the longest. I am sure there are other O or X ring chains that are worthy of consideration such as Renthal and a few other brands but I have no experience with the BikeMaster ones. I would never recommend a standard roller chain for the TW simply because of the filth that goes with them and the constant need for lubrication, cleaning and adjustments. WIth a ringed chain there is little need for external lubrication other than an occasional spray or the wax type lube that dries and does not fly all over the rear of your bike and wheel. One word of caution if you do go with a ringed chain. DO NOT ever use a high pressure spray washer directly onto the chain that could blow the rings out and never use chemicals on it that could attack the O ring rubber and cause them to dissolve.
    Xracer likes this.
    1987 Yamaha BW350 Big Wheel
    Jan 2018
    Vancouver Island
    36
    I have been looking at the DID VX but at 5 times the price of a regular chain it’s a hard pill to swallow! I know it will probably last 5 times longer though...
    reddave likes this.
    Pleasanton, CA
    5,721
    Quote Originally Posted by BikeNbowHNTR View Post
    I have had good luck with these O-ring chains:
    KMC 428 O-Ring Chain - 132 Links - Black 428UO x 132L
    Jun 2016
    New Rochelle, New York
    1,766
    Exactly as Gary L. said. In a world where "you get what you pay for" this chain lives up to the moniker. I have not had to adjust in over 2500 miles. I "WANT" to adjust out of guilt but the increments on the snails would make it too tight so I'm biding my time. Maybe in late Fall when I do an oil change?
    Ironically the stock chain that comes on the TW is also a DID but the lowest grade piece-of-crap they can sell. I guess that would be a "regular chain"?
    Should be a no-brainer that you want the best you can get with anything to do with your driveline. Just buzzing around town, get a good "O" ring chain. Sharing time off-road get a big-boy chain for your little boy bike... the VX.
    This close-up where I'm installing the clip should tell you the difference between this type of chain (which I never heard of before owning a TW) and others:
    Pay no attention to the upgraded different sprocket. If I had to do it again the stock sprocket size was fine though if and when you change a chain I've always changed the sprocket too. But lining up the OEM Chain and the VX side-by-side to get the proper link-count it was apparent what the difference and level of quality there was between the two.
    Just had the same chain installed on my XR250L and that bike actually has something that the TW doesn't have, head-snap torque.
    MtnMan75 likes this.
    1995 BMW K75 (Elec Start)
    Member MtnMan75's Avatar
    Jul 2019
    MD, USA
    82
    DID VX on mine... You do want to check it after the first few hundred miles, there is usually some initial stretch, but after that it is pretty long durations between any adjustment compared to an old style chain. Been true of most chains I've run. O-rings have a little more resistance compared the older regular chains and many argue it robs a little horsepower (to me it seems it would be negligible... they seem stiff while they're cold but have great free play once they get warmed up). Biggest benefit is they require a lot less maintenance and that maintenance is less involved as well. I just run a grunge brush down the top and bottom with some DuPont cleaner, wipe with a rag, and thoroughly coat with with lube (and again I like the DuPont wax based stuff as it tends to grab less dust). No need to take it off the bike or give it a cleaner/oil bath each time if you've had it in the muck. Big benefit imo.
    2013 TW200
    2013 DRZ400S
    1999 Bombardier 500 Traxter
