Bike dying when put into 1st from neutral
Results 1 to 10 of 17
Like Tree4Likes
Thread: Bike dying when put into 1st from neutral
    Senior Member Errtu's Avatar
    Jul 2017
    Buena Vista, CO
    141
    This just started happening over the last week. Pull choke and start bike.
    Let bike idle for about a min or two. Push choke in. Bike idling just fine.
    Pull clutch and go into 1st gear and the bike lurches a little and stalls out.
    2001 Yamaha TW200
    2015 Nissan Xterra PRO-4X
    Jun 2017
    Milwaukee, WI
    1,324
    Kickstand needs to be up.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Jun 2017
    Milwaukee, WI
    1,324
    Or could be clutch plates are sticking. Let it warm up or give it more throttle. Pretty common on TDubs. Before you start it you can walk the bike a bit in first gear while holding the clutch lever that helps free them up too.
    01 SOLD
    96 SOLD
    89 restored SOLD
    03 SOLD
    Jul 2017
    Buena Vista, CO
    141
    Quote Originally Posted by Badgerflorida View Post
    Kickstand sensor removed.
    2001 Yamaha TW200
    Jul 2017
    Buena Vista, CO
    141
    What would cause the clutch plates sticking all of a sudden?
    2001 Yamaha TW200
    Junior Member JacobK's Avatar
    Jul 2016
    Ireland
    17
    Mine does this most mornings. I rev the engine a bit before putting it in first. I bought stiffer clutch springs to try and see if that works but don't know if it will.
    BC
    784
    Quote Originally Posted by Errtu View Post
    As the weather cools...nights are longer...oil has more time to thicken a bit more.
    I'll let mine warm up for about 3-5 minutes in the morning, then I straddle it and flat foot it out through the gate. While I'm rolling, I'll pull in the clutch and shift into first.
    Usually by then, there's no clunk or stalling.
    Another option would be to let it warm up, then shut it down...then shift into first and (with the clutch still pulled in) start it up again and off you go!
    If this doesn't work...then you must still have some cut-out (sidestand or clutch switch) still being activated somehow.
    2008 TW200
    Southwest corner of BC Canada
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,853
    Before you start it, put it in gear, pull in and hold the clutch lever, then firmly & quickly push the bike back & forth. If necessary, as HARD as you can. Won't hurt a thing.
    That will usually free stuck clutch plates.
    If that doesn't do it, then think about the more complicated stuff.
    Like my Ol' Daddy used to say..."Pluck the low-hangin' fruit!"
    "Faster, faster, faster, until the thrill of speed overcomes the fear of death."
    - Hunter S. Thompson
    Still, I rise!
    "Give a Damn"
    - C. M. Howe, Jr.
    Mar 2019
    Austin Tx
    260
    The clutch sticking thing is REAL.
    If you pull in the clutch and move the bike back/forth to break loose the clutch before going into gear, it general fixes that issue. For whatever reason it's a thing will many of the TWs. I have had less issues with mine as I put more miles on it. But that sounds exactly like what you're dealing with.
    UncleRandy likes this.
    2019 Yamaha TW200
    - DGv2 Slip On
    - Custom Oil Cooler
    - Manracks Seat Rack
    - Ricochet Skid Plate
    - Oversizzed Footpegs
    - Cycra ProBend Handguards
    1973 Yamaha RD350
    Senior Member RaZed1's Avatar
    Oct 2015
    300
    This seems to be a common complaint on newer TW's that have the reshaped clutch discs, but it suddenly happening on an older one is a bit odd.
    Cooler weather combined with thicker oil can cause more drag and a bit more of a clunk when dropping into gear for the first time, if your idle is set too low this can stall it out. Might try changing to a thinner weight oil moving into cooler months. I definitely notice the "clunk" is more pronounced using 15-50 oil vs 5-40, although once warmed up both feel perfectly smooth, or as smooth as a TW's transmission ever is.
    Oil that's due to be changed tends to drag clutches a bit more also. Could be a factor of a few of those things.
