Front sprocket replacement....refresh my memory.
Results 1 to 6 of 6
Like Tree6Likes
  • 5 Post By RockyTFS
  • 1 Post By tylermoney
Thread: Front sprocket replacement....refresh my memory.
    BC
    623
    It's been a while since I've done this...
    When the side case comes off...will I lose all my oil? I remember lying it down on my lawn to do this once.
    Also, there's one (or two) dowel pins that are present...do they like to fall into the engine, or do they stay put?
    Going to try a 15T on the front...just to see if it makes much difference with a 50 or 51 rear.
    2008 TW200
    Southwest corner of BC Canada
    Hailey, ID
    3,324
    Lay the bike on its right side (after draining or using half a tank). You won't lose any oil. The dowel pins can definitely fall into the engine but rocking the side cover gently as you pull it off helps. Since you are aware of this possibility the first thing to do is look to see where they are. If they stayed with the side cover put them back in the engine with some heavy grease to hold them.
    The big danger when changing out the front sprocket is pinching the stator wires. When you get the cover started on the pins don't push it all the way on until you have inspected the wires and the little rubber plug from the chain side and verified that they are still in place.
    Make a cardboard mock-up of the side cover and place the bolts in the holes as they come off.
    Donzo, TW_in_BC, SanDue and 2 others like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    BC
    623
    Thank you.
    I think I removed the battery as well...
    2008 TW200
    Mar 2019
    Austin Tx
    225
    This is a great video. He drains his oil completely:
    GOF likes this.
    2019 Yamaha TW200
    - DGv2 Slip On
    - Custom Oil Cooler
    - Manracks Seat Rack
    - Ricochet Skid Plate
    - Oversizzed Footpegs
    - Cycra ProBend Handguards
    1973 Yamaha RD350
    Hailey, ID
    3,324
    Quote Originally Posted by TW_in_BC View Post
    Thank you. I think I removed the battery as well...
    Mine is an AGM so I didn't think of that.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member jeepster09's Avatar
    Nov 2010
    Twin Cities Minnesota
    235
    I didn't lose any oil with bike straight on motorcycle jack, I didn't unhook battery either.
    "Life Member NRA"
