Low Power in High Gears - Solved - Bad Air Filter
Results 1 to 5 of 5
Like Tree15Likes
  • 9 Post By Badgerflorida
  • 2 Post By RockyTFS
  • 1 Post By tylermoney
  • 1 Post By white mule
Thread: Low Power in High Gears - Solved - Bad Air Filter
    Jun 2017
    Milwaukee, WI
    1,302
    My 05 had been stumbling in 4th and 5th. I cleaned the carb and still no improvement. Played with every possible pilot setting with no luck. Checked petcock and fuel flow. Even ran it without the gas cap to rule out possible venting issue.
    I had inspected the air filter a number of times, but today when I removed it, it came out in multiple pieces. Installed an old one I had forgotten to throw away and now it runs like a champ.
    01 SOLD
    96 SOLD
    89 restored SOLD
    89 (restoration in process)
    05 (restoration in process)
    03 SOLD
    04 in great condition
    Hailey, ID
    3,409
    Looks can be deceiving.... Out here there is enough dust that I have to clean and re-oil mine about every 500 miles. I got the filter on the first 2010 TW to last about 10,000 miles before it showed signs of disintegrating.
    tylermoney and Badgerflorida like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Mar 2019
    Austin Tx
    259
    Always a ghost to chase when working on bikes (or I guess anything mechanical for that matter). Glad you solved yours without too much hassle! It's been a while since I looked at my air filter. This makes me want to check in on it. I'm only at about 2,800mi, and it looked fine at 1k miles.
    Badgerflorida likes this.
    2019 Yamaha TW200
    - DGv2 Slip On
    - Custom Oil Cooler
    - Manracks Seat Rack
    - Ricochet Skid Plate
    - Oversizzed Footpegs
    - Cycra ProBend Handguards
    1973 Yamaha RD350
    Hailey, ID
    3,409
    Looks can be deceiving....wash it out with soap and hot water in a pan and see how dirty the water gets!
    Badgerflorida and tylermoney like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member white mule's Avatar
    Jan 2014
    NorthWet Oregon
    181
    When I went to Moab last spring I got a sheet of filter foam and cut and oiled a bunch of filters. The idea was that every day I could install a fresh filter and not have to spend my time washing out filters. It is a lot cheaper to buy a sheet of UNI foam than buying OEM stuff. Now I have a lifetime of filters.
    Rickhem likes this.
    Me and my white mule
