All Turn signals not working on 87 TW
Results 1 to 10 of 13
Like Tree7Likes
Thread: All Turn signals not working on 87 TW
    Junior Member kgb's Avatar
    Mar 2015
    9
    I had a lot of work done on my bike and just realized none of the turn signals are working. Any easy diagnostic steps to determine the problem? I moved away from the shop that serviced the bike or I would take it back.
    GOF
    GOF is offline
    Senior Member GOF's Avatar
    Dec 2018
    Buffalo, NY
    378
    I would start by seeing if the horn works. Then check if you have power at the flasher.
    There is a link to the service manual, with wiring diagram, in my signature line.
    reddave likes this.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Mar 2017
    Yuba City, CA
    406
    Quote Originally Posted by kgb View Post
    What kind of work? If you had LED lights installed, for example, your old flasher won't flash.
    Mar 2015
    9
    The work done was carb, new levers and tires; nothing electrical.
    Horn works. Can’t get to your content, I have a service manual; what section/pages. Thanks
    GOF
    GOF is offline
    Dec 2018
    Buffalo, NY
    378
    The beginning of the electrical section. You'll find a diagram. If the horn works then see if there is power to the flasher. The horn is on the same circuit. Check for lose connections, bad grounds, things like that. Could be a bad flasher. But best to test things before tossing parts at it.
    reddave and CJ7Pilot like this.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Senior Member reddave's Avatar
    May 2018
    South Park, CO
    331
    10 points to GOF for linking the service manual in his signature! Very thoughtful, sir.
    GOF and Fred like this.
    1987 Yamaha TW200
    GOF
    GOF is offline
    Dec 2018
    Buffalo, NY
    378
    Quote Originally Posted by reddave View Post
    It was some else's idea. I just ran with it.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Mar 2015
    9
    FYI, this is the message I received trying to open the link;
    “To view links or images in signatures your post count must be 10 or greater. You currently have 0 signatures”
    GOF
    GOF is offline
    Dec 2018
    Buffalo, NY
    378
    Fred likes this.
    1988 Suzuki Savage
    1987 Yamaha TW200
    Mar 2015
    9
    Awsum! Thank you so much for the help; I’ll keep you informed!
    GOF likes this.
