chaon guide bolt
Results 1 to 6 of 6
    Senior Member niqhowie's Avatar
    Oct 2012
    New Mexico
    123
    Im missing this bolt and ive gone to oreillys, autozone, and a couple of hardware stores to try and find the right metric threading. Under 10mm, Can anyone help? I imagine this plastic piece is essential.
    "Peace be the journey"
    MY BIKE BUILD- Hidden Content
    -2012 tw200
    6,981
    My guess is M6-1 and about 16mm long.
    Desert, SoCal
    7,369
    You're also missing the taper pin washer. You can install the bolt temporarily with a flat washer, but try to get the right washer pretty quick so you won't cookie cut the hole in the rubber with the flat washer. That little rubber chingas costs over 50 bucks and requires swingarm removal in order to replace it. The correct washer is under two bucks.
    Loctite, Loctite, Loctite.
    Member budgar's Avatar
    Feb 2013
    Newer Mexico
    35
    Funny thing, i'm pulling the head last night and notice mine is missing the same bolt and washer. Thanks for asking about it before i had to
    Germany, Werdau
    1,014
    So "cheap"???
    In Germany we have to pay ~82 USD for it (this price is like a bad joke).
    -> But CeMoto does have a really good fitting part for ~22 USD.
    Tony, I think you're right it's a M6x16mm.
    Oct 2012
    New Mexico
    123
    Thank you for the responses! I'll more than likely get an oversized washer so it wont cut through it! thanks for the heads up on that Lizrdbrth! "chingas" haha I'm hispanic i've heard that more than once!
    Sebastian- CeMoto.com? do you have a link?
    -2012 tw200
  1. Guide to building an Adventure Ready TW200
    By mrbracket in forum Sticky threads
    Last Post: 10-04-2016, 08:24 PM
  2. Beginner's Guide to Fork seal replacement
    By B-dub in forum Technical Write-Ups
    Last Post: 08-08-2012, 06:37 AM
  3. aftermarket chain guide/tensioner?
    By Point37 in forum Technical Help
    Last Post: 04-27-2012, 08:36 AM
  4. Valve Guide Extractor/replacer TOOL.
    By christddel in forum Technical Help
    Last Post: 01-07-2011, 02:59 PM
  5. Cam Chain Guide Replacemenet
    By thumper in forum Technical Help
    Last Post: 10-23-2010, 11:30 PM
