Why is my oil filter smushed?
Results 1 to 10 of 13
    Senior Member xdac's Avatar
    Mar 2011
    Gilbert AZ
    1,076
    Found this today...any ideas why its smushed down in the middle? It looked like the first pic after my break in, went on a 5 hour ride after the oil change, pulled everything apart today to change the oil again and found the filter smashed.
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    Well....that's a new one. I have no idea. That would have to be some real oil flow to collapse the filter.
    Tenaciously Deviant Unwittingly Brilliant
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Perhaps it was not seated/centered when the cover was screwed on?.....looks kinda old?.
    Mar 2011
    Gilbert AZ
    1,076
    Quote Originally Posted by frog13 View Post
    Its from my 87 parts bike that i switched over. I liked the metal screen...easy to wash out and clean. Theres only one way it can go in as far as i know....right?
    Nov 2011
    Alabama
    326
    No, he's probably right. It only goes in one way but if the cover wasn't aligned exactly it could have caught the edge of the filter and squeezed it. It's so flimsy ya probably wouldn't have even noticed.
    Poway CA.
    2,100
    Quote Originally Posted by xdac View Post
    To much HP!
    Senior Member jontow's Avatar
    Oct 2010
    Potsdam, NY
    701
    I'd considering buying a handful of the yamaha filters with metal screen: they're pleated, and because of that, I'd bet a bit stronger.
    In the first pic: you making crafting glitter, or what?
    1997 TW, well loved, a bit modified.
    Senior Member mekdad's Avatar
    Jan 2012
    idaho
    188
    Check for the old gasket still in the bike. maybe you stacked them.
    You never know what you can do until you have to undo something you have done.
    Nov 2011
    Alabama
    326
    Hold on... Is there any other type of filter besides the metal screen. That's what I have and it's the only kind I've seen. Got a different one?
    Senior Member TWisty's Avatar
    North GA Mountains
    149
    Quote Originally Posted by Fort Payne View Post
    The OEM filter has the brass screen.
    Replacement filters (from Yamaha) are pleated paper.
  1. Oil filter mix-up
    By accor415 in forum Technical Help
    Last Post: 07-04-2014, 08:47 AM
  2. Air filter Mod
    By jimmytanko in forum Technical Help
    Last Post: 10-03-2012, 06:41 PM
  3. oil filter
    Last Post: 07-06-2012, 09:00 AM
  4. OEM Oil Filter
    By TWisty in forum Technical Help
    Last Post: 06-12-2012, 08:08 PM
  5. Old oil filter
    By Lido in forum Technical Help
    Last Post: 09-11-2011, 10:14 AM
smushed in middle
why is my oil filter crushed
why is my oil filter smashed
