Choke off - Fast idle ~ at times
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By TW_in_BC
Thread: Choke off - Fast idle ~ at times
    Junior Member BryanB's Avatar
    Aug 2018
    Gunnison, Co
    6
    2019 - 100% stock
    Occasionally my 2019 has a fast idle like the choke is on, but it's not. In fact one time when I noticed this I pulled the choke to the full on position and the idle slowed down to a more normal level. Before I started messing with something I wanted to ask for advice from the experts. Maybe I should take it back to the dealer but their service department doesn't have the greatest reputation.
    I live in Colorado at 7,700 feet and some rides have taken me a little over 11,000 feet if that matters.
    Thanks in advance for any advice offered.
    2019 TW200 (Mine) 2017 TW200 (Wife's)
    BC
    665
    If it is new...I would take it back to the dealer.
    In the meantime, check to see if your cables are binding...ie: does this happen when you turn the bars from one side to the other, or is it just a random occurrence?
    MtnMan75 likes this.
    2008 TW200
    Southwest corner of BC Canada
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    802
    I've experienced similar symptoms due to a lean condition. The choke gets the mix a bit more rich and idle returns.
    The bear slayer!
