What is this, and what does it mean?
Results 1 to 8 of 8
    Member decade03's Avatar
    Sep 2012
    NC
    34
    I'm fairly new to motorcycle but still learning. Can anyone tell me what this little ring is called? It's clear and last time I checked it, it was a bit dark with what I'm guessing was oil.
    https://photos-3.dropbox.com/t/0/AAB...size=1600x1200
    But it's clear now (empty) and I don't know if that's an indication that i've replaced the oil (which I did, since I had to drain it to replace the sprockets) or that it needs oil? If it needs oil then that's the sign of a major leak i'm not seeing since it was only yesterday that I replenished it.
    2009 TW200, first time rider!
    1,110
    I don't think your picture link is working....
    Edit....I've got a Dropbox account and logged in....still couldn't see it.
    Member Twowheeler's Avatar
    Jan 2013
    Jacksonville FL
    79
    Is it the right side case?
    You might be looking at the oil fill level, lack of better words a glass eye so you can see oil level. If the bike is parked on its stand then the eye will be empty. But if you hold the bike up straight you will see the oil.
    Senior Member rm_hm's Avatar
    1,619
    Only dropbox members can see your pictures
    Error (403)
    It seems you don't belong here! You should probably sign in. Check out our Help Center and forums for help, or head back to home.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Your photo is listing an error code "403"?.
    Aug 2011
    Cayce, SC
    3,109
    This thread is useles without pics
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    May 2012
    Tucson, AZ
    976
    decade03, the easiest way to share photos on this forum is to open a photobucket account, upload your photos there, and then from photobucket you can "direct link" copy/paste them into the field on the "insert image" tool on the forum full editor.
    You can keep your albums private on photobucket and still post the photos here, if privacy is an issue.
    Links are boo, pics are yay!
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    Sep 2012
    NC
    34
    Sorry all, I was sure the picture was available. In fact I was talking about the glass eye on the right side of the bike, which reads the oil level. And I did manage to fix the problem! Just a dumb amateur mistake. The bike was on it's peg and the oil could not be read until it was upright as TwoWheeler noted. Sorry for wasting your time gentlemen but I appreciate your replies!
what does the tw mean on a yamaha tw 200
