float bowl drain screw
Results 1 to 6 of 6
    Member boylstonrider's Avatar
    Jordan,Boylston NY
    68
    I stripped out my drain screw but got it out...the parts fiche calls it Air Screw, #27...Is that the drain screw?
    Sep 2012
    Northwestern Oregon
    1,092
    Man, those screw heads strip very easily. Even using a JIS screwdriver they still want to strip. I think that Yamaha makes them out of some kind of lead alloy just to laugh at us.
    What year is your bike? For the newer models the part number is 4JP-14104-00-00 and is described as an Air Screw.
    Jordan,Boylston NY
    68
    Quote Originally Posted by Old White Truck View Post
    2008... that's the part number i got ...description threw me off...and they total suck...Both our TW,s striped.... thanks
    Sep 2012
    Northwestern Oregon
    1,092
    Quote Originally Posted by boylstonrider View Post
    Yep that is the part number I ordered for my 2008 so I know it works.
    Junior Member smlangford91's Avatar
    Jul 2013
    11
    how did you get it out? im having the same problem on my '06 right now
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,399
    Yes, that's the drain screw.
    I destroyed the head of my original one when I removed it. I used a flat blade screw driver.
    When I put in the new one I used anti seize on the thread...and don't over tighten it.
    Jb
  1. float bowl chamber
    By phazer in forum General Discussion
    Last Post: 10-13-2011, 05:40 PM
  2. stripped out bowl drain screw
    Last Post: 09-05-2011, 09:11 PM
  3. Float Bowl Screw
    By mike m in forum Technical Help
    Last Post: 09-04-2011, 07:03 AM
  4. Carb float bowl screws
    By jbfla in forum Technical Help
    Last Post: 10-05-2010, 02:57 PM
  5. Part number for Carb float bowl drain screw?
    By RadV in forum Technical Help
    Last Post: 09-16-2010, 06:16 PM
how drain carb bowl
