Rattle
Results 1 to 10 of 12
Like Tree13Likes
Thread: Rattle
    Member RidgeRunner's Avatar
    Oct 2019
    Buck Ridge, GA
    44
    Rattle
    I hate a rattle. Today I discovered the cap on my muffler is vibrating. It is loud enough to hear over the exhaust. I tried to remove the screw at the bottom of the cap, but it will not budge. Should there be a spacer between the muffler and the cap? This may seem a bit OCD to some, but I would like to stop the rattle.
    Any thoughts?
    Ken likes this.
    2017 TW200
    Shrinko SR241 front tire
    Seat Concepts seat
    DID XV428 xring chain
    JT sprockets - 47T rear
    WPS Lithium battery
    IMS Super Stock footpegs
    Small rear luggage rack
    Removed front fork side reflectors
    Removed passenger foot pegs and mounts
    Removed some decals
    Modified license tag mount
    White front fender
    White headlight cowl
    D-FLEX handguards
    LED headlight - soon
    Pleasanton, CA
    5,782
    Since you can't get the end cap off anyways, here is what you could do (assuming that aesthetics are not too important to you).
    Take a wire brush and clean the paint off a small area of the seam between the end cap and the body of the muffler. Then ride your bike to your friendly local muffler shop and ask if they would kindly put a small tack weld on there to stop the rattle. Then use a file or grinder to smooth out any sharp edges and hit it with shot of flat black spray paint. This should be a semi-permanent fix that could always be gound off in the future if needed.
    Hailey, ID
    3,405
    This doesn't make much sense to me. The usual thing about older mufflers is that not only is the bolt frozen, but the end cap is also. However, the spark arrestor inside the muffler may well have partially disintegrated and that could be causing the noise. You need to do multiple applications of PB Blaster and heat from a torch to the bolt to see if you can get it out and see what's going on in there.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Frosty Hollow
    13,170
    Quote Originally Posted by RidgeRunner View Post
    Any thoughts?
    Easily correctable. You choose the correct silencer!
    Nichea likes this.
    Oct 2019
    Buck Ridge, GA
    44
    Most of your "silencers" seem to have a lot of experience.
    In the Air Force we called it Brogan Maintenance.
    I would prefer to get the end cap off. I'll work on the screw.
    admiral likes this.
    2017 TW200
    Seat Concepts seat
    WPS Lithium battery
    Removed some decals
    White front fender
    D-FLEX handguards
    Oct 2019
    Buck Ridge, GA
    44
    Problem solved.
    I removed the muffler so I could turn it over and give my full attention to that stuck screw.
    I soaked it, tapped it, left it over night.
    I soaked it again, tapped it again, twisted, put my full body weight into the screwdriver, heated it, tapped it, and eventually cussed it. The screw would not budge.
    During one of my cussing episodes, I grabbed a universal "adjuster" as suggested by admiral and smacked the muffler three times at the seam next to the screw.
    Problem solved. No rattle. Thanks admiral for your sage advice.
    TW-Brian, admiral and Dryden-Tdub like this.
    2017 TW200
    Seat Concepts seat
    WPS Lithium battery
    Removed some decals
    White front fender
    D-FLEX handguards
    Pleasanton, CA
    5,782
    Congratulations!
    Since you were able to that JIS screw out, I'd suggest replacing it with one that you can put an Allen wrench on, and using a generous amount of anti-sieze on the threads when you put things back together. A future owner will appreciate it!
    admiral likes this.
    Hailey, ID
    3,405
    Admiral's "adjusters" are the best.....sometimes.
    admiral likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Oct 2019
    Buck Ridge, GA
    44
    Congratulations!
    TW, you misunderstood. I was not able to get the screw out. I just bent the muffler enough to wedge against the cap and stop the rattle.
    TW-Brian likes this.
    2017 TW200
    Seat Concepts seat
    WPS Lithium battery
    Removed some decals
    White front fender
    D-FLEX handguards
    Junior Member TDubbery's Avatar
    Sep 2019
    Southeast USA
    13
    Weird mine rattles from the end of the exhaust when started and I think it did since day one. Once the bike warms up it goes away, though. I haven't gotten around to checking it out yet but now I'm too curious.
    2020 TW, 2000 miles and growing
    YouTube: Moto Politics - Hidden Content
    "If you think you can or you think you can't, you're right"
